Cisco 2504 OEAP NAT directly connect AP's no ip
sarnovait
I setup my 2504 to work with OEAP.  When I enabled NAT on the management interface the one AP I have directly connected to the WLC is no longer getting an IP address.  Any idea why this is?
Stephen Rodriguez
First, it is not recommended to have an AP directly connected to the WLC, you really need to connect it to an upstream switch and let it connect that way.
My first thought would be that you need to take a look a the below link that talk about how the NAT ip commands work.
http://www.cisco.com/en/US/docs/wireless/controller/7.0MR1/command/reference/cli70MR1commands.html#wp14087790
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
sarnovait
Any help here?
Stephen Rodriguez
HTH,
Steve
HTH,
Steve
Just so you know i only have one AP plugged directly in the WLC becuase there is no POE in this area and the AP sits 5feet from the WLC.
I ran the following commands which seem to fix my issues.
config ap link-latency disable all
config network ap-discovery nat-ip-only disable
Thanks!
