Hall of Fame Super Silver
Cisco 340 & 350 'Warm Reboot'
Is there a way you can have 340's & 350's do a warm reboot without having to go in each AP? I know if you do a firmware upgrade it will automatically reboot the AP, but if you have a mix environment of 340's & 350's will doing a 'distribute firmware' upgrade have any affect on the other model?
Thanks!
-Scott
Community Member
Re: Cisco 340 & 350 'Warm Reboot'
You could:
- Power cycle at the Power-over-Ethernet modules
- Use SNMP set command for reboot to each IP
- Use Wavelink's software
Matthew Wheeler
Chief Wireless Architect
www.BlueModal.com
Thanks! I just ended up doing a distribute firmware.
-Scott
188
