Community Member
Cisco 350AP - What happened?
Hi all,
What happen to my Cisco 350 AP as below?
Testing DRAM...
(press <esc> to bypass)
DRAM OK
Power-on reset.
Copyright 1996-2000 Cisco Systems, Inc.
Copyright 1984-2000 Wind River Systems, Inc.
System ID: 0040965ABFA5
Motherboard: MPC855 50MHz, 8192KB FLASH, 16384KB DRAM, Revision B0
Bootstrap Ver. 1.09: FLASH, CRC 710B6415 (OK)
Initialization: OK
Memory Bank total used left
DRAM 16738168 0 16738168
Config 524288 212 524076
FLASH 7733248 4291344 3441904
Memory Bank:File address size encoding type flags
a) Config:AWC_ConfigDB FE020000 212 AiroDB1 Data 0000
b) FLASH :IOS_Upgrade 1.0 FE0A0000 393268 none Exec 0801
c) FLASH :IOS_C350_BOOT 2 FE100034 393256 none 0x09 0800
d) FLASH :IOS_C350_TAR 2 FE16005C 3467304 none 0x0A 0800
e) FLASH :IOS_Upgrade_Envs 1.0 FE4AE884 136 none 0x0C 0800
f) FLASH :AWC PCMCIA FPGA 0.14 FE4AE90C 37380 none FPGA 0000
Cisco IOS automatic field upgrade image, ESC to terminate
..10....9....8....7....6....5....4....3....2....1..
upgrade: Compare ok first load file 0
upgrade: Compare ok first load file 1
upgrade: Compare ok first load file 3
upgrade: IOS Configuration component not available
upgrade: Invalid or missing installation key (BR350 not supported)!
Depress ESC key to reboot
Please let me know what happen and how I could recover it.
Thanks a lot
Ron
Community Member
Re: Cisco 350AP - What happened?
Where you trying to upgrade the IOS with bridge firmware (BR350). That is your last error message.
Community Member
I got this error after I upgrade to IOS for this AP350. This was the only error message I got.
Thanks!
135
