Cisco 5500 Series WLC Field Recovery Compatibility
Is Software Version 7.2.111.3 compatible with Field Recovery Image Version 7.6.95.16.
1 REPLY
VIP Purple
Hi,There are three type of
There are three type of image:
Primary is the latest image you upgraded to.
Backup is the last image you upgraded from.
The Field Recovery Image is that when you interrupt the bootup process.
So dont worry about this image.
Mian is the primary and backup image...that must be compatible with AP.
Dont forget to rate helpful posts
361
