Cisco 851w and Linksys WPS54G printserver
Recently i bought a Cisco 851W to replace a Linksys router for a customer.
The wireless connection between the router and printserver were fine before i replaced the linksys with a Cisco. But when i implemented the Cisco router things started to go wrong.
The wireless connection with the print server drops multiple times per day and requires a reboot from both the router and printserver to get it back online.
Here's the config that matters on the Cisco 851W:
dot11 ssid *
vlan 1
authentication open
authentication key-management wpa
guest-mode
infrastructure-ssid optional
wpa-psk ascii 0 *
interface Dot11Radio0
no ip address
encryption mode ciphers tkip
encryption vlan 1 mode ciphers tkip
ssid *
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
bridge-group 1
interface BVI1
ip nat inside
no ip route-cache cef
no ip route-cache
Any help is greatly appreciated.
Thank you in advance!
Ron Aarts
Cisco Engineer Neon-networking
1 REPLY
Hall of Fame Super Silver
Re: Cisco 851w and Linksys WPS54G printserver
Since the printserver is 802.1g, try to disable 1.0, 2.0, 5.5 and 11.0 and set the others to basic. You can also try to disable shor preamble on the interface Dot11Radio0.1 no preamble-short.
Maybe also update the printserver to the latest firmware.
-Scott
572
