Community Member
Cisco 871W as Radius Local Authenticator
We are tring to configure an Cisco 871w as an access point and also as an local authenticator.The NAS would be the same server. The sample config is as below
aaa group server radius rad_eap
server 10.10.200.1 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip dhcp excluded-address 10.10.200.1
ip dhcp excluded-address 10.10.200.31 10.10.200.254
ip dhcp pool <pool_name>
import all
network 10.10.200.0 255.255.255.0
dns-server 141.x.x.6 141.198.136.12
default-router 10.10.200.1
lease 0 2
interface Dot11Radio0
ip address 10.10.200.1 255.255.255.0
ssid <SSID Name>
authentication network-eap eap_methods
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
ip classless
ip http server
ip http secure-server
radius-server local
nas 10.10.200.1 key 0 <key>
user test nthash xxx
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.10.200.1 auth-port 1645 acct-port 1646 key <key>
radius-server vsa send accounting
By the above config, we are trying to make the clients to authenticate with username created in the RADIUS which is this router and get an ip address through DHCP pool configured for the same. Will the above config does the same. Kindly let me know.
Thanking You
Anantha Subramanian Natarajan
Gold
Re: Cisco 871W as Radius Local Authenticator
The config should work for LEAP, but you still need to specify an encryption type (encryption mode wep mandatory).
Community Member
Thanks .
Worked with cipher mode tkip and used WPA for key management.
Once again,Thanks for the repsonse
442
