Cisco 871w, radius server local, and leap or eap-fast will not authenticate
Hello, i trying to setup eap-fast or leap on my 871w.  i belive i have it confiured correctly but i can not get any device to authenticate to router.  Below is the confiureation that i being used.  any help would be welcome!
! Last configuration change at 15:51:30 AZT Wed Jan 4 2012 by testtest
! NVRAM config last updated at 15:59:37 AZT Wed Jan 4 2012 by testtest
version 12.4
configuration mode exclusive auto
service nagle
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service linenumber
service pt-vty-logging
service sequence-numbers
hostname router871
boot-start-marker
boot-end-marker
logging count
logging message-counter syslog
logging buffered 4096
logging rate-limit 512 except critical
logging console critical
enable secret 5 <omitted>
aaa new-model
aaa group server radius rad-test3
server 192.168.16.49 auth-port 1812 acct-port 1813
aaa authentication login default local
aaa authentication login eap-methods group rad-test3
aaa authorization exec default local
aaa session-id common
clock timezone AZT -7
clock save interval 8
dot11 syslog
dot11 ssid test2
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 <omitted>
dot11 ssid test1
vlan 1
authentication open
dot11 ssid test3
vlan 3
authentication open eap eap-methods
authentication network-eap eap-methods
no ip source-route
no ip gratuitous-arps
ip options drop
ip dhcp bootp ignore
ip dhcp excluded-address 192.162.16.49 192.162.16.51
ip dhcp excluded-address 192.168.16.33
ip dhcp excluded-address 192.168.16.1 192.168.16.4
ip dhcp pool vlan1pool
   import all
   network 192.168.16.0 255.255.255.224
   default-router 192.168.16.1
   domain-name test1.local.home
   lease 4
ip dhcp pool vlan2pool
   import all
   network 192.168.16.32 255.255.255.240
   default-router 192.168.16.33
   domain-name test2.local.home
   lease 0 6
ip dhcp pool vlan3pool
   import all
   network 192.168.16.48 255.255.255.240
   default-router 192.168.16.49
   domain-name test3.local.home
   lease 2
ip cef
ip inspect alert-off
ip inspect max-incomplete low 25
ip inspect max-incomplete high 50
ip inspect one-minute low 25
ip inspect one-minute high 50
ip inspect udp idle-time 15
ip inspect tcp idle-time 1800
ip inspect tcp finwait-time 30
ip inspect tcp synwait-time 60
ip inspect tcp block-non-session
ip inspect tcp max-incomplete host 25 block-time 2
ip inspect name firewall tcp router-traffic
ip inspect name firewall ntp
ip inspect name firewall ftp
ip inspect name firewall udp router-traffic
ip inspect name firewall pop3
ip inspect name firewall pop3s
ip inspect name firewall imap
ip inspect name firewall imap3
ip inspect name firewall imaps
ip inspect name firewall smtp
ip inspect name firewall ssh
ip inspect name firewall icmp router-traffic timeout 10
ip inspect name firewall dns
ip inspect name firewall h323
ip inspect name firewall hsrp
ip inspect name firewall telnet
ip inspect name firewall tftp
no ip bootp server
no ip domain lookup
ip domain name local.home
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip accounting-threshold 100
ip accounting-list 192.168.16.0 0.0.0.31
ip accounting-list 192.168.16.32 0.0.0.15
ip accounting-list 192.168.16.48 0.0.0.15
ip accounting-transits 25
login block-for 120 attempts 5 within 60
login delay 5
login on-failure log
memory free low-watermark processor 65536
memory free low-watermark IO 16384
username testtest password 7 <omitted>
archive
log config
  logging enable
  logging size 255
  notify syslog contenttype plaintext
  hidekeys
path tftp://<omitted>/archive-config
write-memory
ip tcp synwait-time 10
ip ssh time-out 20
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
bridge irb
interface Loopback0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
interface Null0
no ip unreachables
interface FastEthernet0
switchport mode trunk
shutdown
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
spanning-tree portfast
interface FastEthernet3
interface FastEthernet4
description Cox Internet Connection
ip address dhcp
ip access-group ingress-filter in
ip access-group egress-filter out
no ip redirects
no ip unreachables
no ip proxy-arp
ip accounting access-violations
ip flow ingress
ip flow egress
ip inspect firewall out
ip nat outside
ip virtual-reassembly
ip tcp adjust-mss 1460
load-interval 30
duplex auto
speed auto
no cdp enable
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 2 mode ciphers aes-ccm
encryption key 1 size 128bit 7 <omitted> transmit-key
encryption mode wep mandatory
broadcast-key vlan 1 change <omitted> membership-termination
broadcast-key vlan 3 change <omitted> membership-termination
broadcast-key vlan 2 change <omitted> membership-termination
ssid test2
ssid test1
ssid test3
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
no cdp enable
interface Dot11Radio0.1
description <omitted>
encapsulation dot1Q 1 native
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip redirects
no ip unreachables
no ip proxy-arp
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 1
interface Vlan2
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 2
interface Vlan3
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
bridge-group 3
interface BVI1
ip address 192.168.16.1 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface BVI2
ip address 192.168.16.33 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface BVI3
ip address 192.168.16.49 255.255.255.240
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip http secure-ciphersuite 3des-ede-cbc-sha rc4-128-sha
ip http timeout-policy idle 5 life 43200 requests 5
ip flow-top-talkers
top 10
sort-by bytes
ip nat inside source list 1 interface FastEthernet4 overload
ip nat inside source static tcp 192.168.16.50 80 interface FastEthernet4 80
ip nat inside source static tcp 192.168.16.50 53 interface FastEthernet4 53
ip nat inside source static tcp 192.168.16.50 3074 interface FastEthernet4 3074
ip nat inside source static udp 192.168.16.50 3074 interface FastEthernet4 3074
ip nat inside source static udp 192.168.16.50 88 interface FastEthernet4 88
ip nat inside source static udp 192.168.16.50 53 interface FastEthernet4 53
ip access-list extended egress-filter
deny   ip any host <omitted>
deny   ip host <omitted> any
remark ----- Bogons Filter -----
deny   ip 0.0.0.0 0.255.255.255 any
deny   ip 10.0.0.0 0.10.9.255 any
deny   ip 10.0.0.0 0.10.13.255 any
deny   ip 127.0.0.0 0.255.255.255 any
deny   ip 169.254.0.0 0.0.255.255 any
deny   ip 172.16.0.0 0.15.255.255 any
deny   ip 192.0.0.0 0.0.0.255 any
deny   ip 192.0.2.0 0.0.0.255 any
deny   ip 192.168.0.0 0.0.15.255 any
deny   ip 192.168.0.0 0.0.255.255 any
deny   ip 198.18.0.0 0.1.255.255 any
deny   ip 198.51.100.0 0.0.0.255 any
deny   ip 203.0.113.0 0.0.0.255 any
deny   ip 224.0.0.0 31.255.255.255 any
remark ----- Internal networks -----
permit ip <omitted> 0.0.0.3 any
deny   ip any any log
ip access-list extended ingress-filter
remark ----- To get IP form COX -----
permit udp any eq bootps any eq bootpc
deny   icmp any any log
deny   udp any any eq echo
deny   udp any eq echo any
deny   tcp any any fragments
deny   udp any any fragments
deny   ip any any fragments
deny   ip any any option any-options
deny   ip any any ttl lt 4
deny   udp any any range 33400 34400
deny   ip 10.0.0.0 0.255.255.255 any
deny   ip 10.10.10.0 0.0.0.255 any
deny   ip 10.10.11.0 0.0.0.255 any
deny   ip 10.10.12.0 0.0.0.255 any
deny   ip any any log
access-list 1 permit 192.168.16.0 0.0.0.63
access-list 20 permit 127.127.1.1
access-list 20 permit 204.235.61.9
access-list 20 permit 173.201.38.85
access-list 20 permit 216.229.4.69
access-list 20 permit 152.2.21.1
access-list 20 permit 130.126.24.24
access-list 21 permit 192.168.16.0 0.0.0.63
radius-server local
no authentication mac
eapfast authority id <omitted>
eapfast authority info <omitted>
eapfast server-key primary 7 <omitted>
nas 192.168.16.49 key 7 <omitted>
group rad-test3
  vlan 3
  ssid test3
user test nthash 7 <omitted> group rad-test3
user testtest nthash 7 <omitted> group rad-test3
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.16.49 auth-port 1812 acct-port 1813 key 7 <omitted>
radius-server vsa send accounting
control-plane host
control-plane transit
control-plane cef-exception
control-plane
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 2 route ip
bridge 3 protocol ieee
bridge 3 route ip
line con 0
logging synchronous
no modem enable
transport output telnet
line aux 0
logging synchronous
line vty 0 4
logging synchronous
transport preferred ssh
transport input ssh
transport output ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
process cpu threshold type total rising 80 interval 10 falling 40 interval 10
ntp authentication-key 1 md5 <omitted> 7
ntp authenticate
ntp trusted-key 1
ntp source FastEthernet4
ntp access-group peer 20
ntp access-group serve-only 21
ntp master 1
ntp server 152.2.21.1 maxpoll 4
ntp server 204.235.61.9 maxpoll 4
ntp server 130.126.24.24 maxpoll 4
ntp server 216.229.4.69 maxpoll 4
ntp server 173.201.38.85 maxpoll 4
end
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Cisco 871w, radius server local, and leap or eap-fast will n
Here is a link that might help
http://www.cisco.com/en/US/solutions/collateral/ns340/ns517/ns430/ns855/white_paper_c11-492842.html
-Scott
-Scott
so this what i am getting now for debug? any thoughs?
010724: Jan  5 16:26:04.527 AZT: RADIUS: Retransmit to (162.168.16.49:1812,1813) for id 1645/2
010725: Jan  5 16:26:08.976 AZT: RADIUS: No response from (162.168.16.49:1812,1813) for id 1645/2
010726: Jan  5 16:26:08.976 AZT: RADIUS/DECODE: No response from radius-server; parse response; FAIL
010727: Jan  5 16:26:08.976 AZT: RADIUS/DECODE: Case error(no response/ bad packet/ op decode);parse response; FAIL
010728: Jan  5 16:26:08.976 AZT: dot11_auth_dot1x_parse_aaa_resp: Received server response: FAIL
010729: Jan  5 16:26:08.976 AZT: dot11_auth_dot1x_parse_aaa_resp: found eap pak in server response
010730: Jan  5 16:26:08.976 AZT: Client d8b3.7759.0488 failed: EAP reason 1
010731: Jan  5 16:26:08.976 AZT: dot11_auth_dot1x_parse_aaa_resp: Failed client d8b3.7759.0488 with aaa_req_status_detail 1
010732: Jan  5 16:26:08.976 AZT: dot11_auth_dot1x_run_rfsm: Executing Action(SERVER_WAIT,SERVER_FAIL) for d8b3.7759.0488
010733: Jan  5 16:26:08.976 AZT: dot11_auth_dot1x_send_response_to_client: Forwarding server message to client d8b3.7759.0488
010734: Jan  5 16:26:08.976 AZT: EAPOL pak dump tx
010735: Jan  5 16:26:08.976 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0004
010736: Jan  5 16:26:08.976 AZT: EAP code: 0x4  id: 0x1  length: 0x0004
0AD05650:                   01000004 04010004          ........
0AD05660:
010737: Jan  5 16:26:08.980 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010738: Jan  5 16:26:08.980 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010739: Jan  5 16:26:08.980 AZT: dot11_auth_dot1x_send_response_to_client: Started timer client_timeout 30 seconds
010740: Jan  5 16:26:08.980 AZT: dot11_auth_dot1x_send_client_fail: Authentication failed for d8b3.7759.0488
010741: Jan  5 16:26:08.980 AZT: dot11_auth_send_msg:  sending data to requestor status 0
010742: Jan  5 16:26:08.980 AZT: dot11_auth_send_msg: client FAILED to authenticate d8b3.7759.0488, node_type 64 for application 0x1
010743: Jan  5 16:26:08.980 AZT: dot11_auth_delete_client_entry: d8b3.7759.0488 is deleted for application 0x1
010744: Jan  5 16:26:08.984 AZT: %DOT11-7-AUTH_FAILED: Station d8b3.7759.0488 Authentication failed
010745: Jan  5 16:26:09.624 AZT: dot11_auth_add_client_entry: Create new client d8b3.7759.0488 for application 0x1
010746: Jan  5 16:26:09.624 AZT: dot11_auth_initialize_client: d8b3.7759.0488 is added to the client list for application 0x1
010747: Jan  5 16:26:09.624 AZT: dot11_auth_add_client_entry: req->auth_type 0
010748: Jan  5 16:26:09.624 AZT: dot11_auth_add_client_entry: auth_methods_inprocess: 2
010749: Jan  5 16:26:09.624 AZT: dot11_auth_add_client_entry: eap list name: eap-methods
010750: Jan  5 16:26:09.624 AZT: dot11_run_auth_methods: Start auth method EAP or LEAP
010751: Jan  5 16:26:09.624 AZT: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
010752: Jan  5 16:26:09.624 AZT: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to d8b3.7759.0488
010753: Jan  5 16:26:09.624 AZT: EAPOL pak dump tx
010754: Jan  5 16:26:09.624 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0031
010755: Jan  5 16:26:09.624 AZT: EAP code: 0x1  id: 0x1  length: 0x0031 type: 0x1
0AD05B50:                   01000031 01010031          ...1...1
0AD05B60: 01006E65 74776F72 6B69643D 746F7973  ..networkid=toys
0AD05B70: 6F6E7067 2C6E6173 69643D72 6F757465  onpg,nasid=route
0AD05B80: 72383731 2C706F72 7469643D 30        r871,portid=0
010756: Jan  5 16:26:09.644 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010757: Jan  5 16:26:09.648 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010758: Jan  5 16:26:09.648 AZT: dot11_auth_dot1x_send_id_req_to_client: Client d8b3.7759.0488 timer started for 30 seconds
010759: Jan  5 16:26:09.656 AZT: dot11_auth_parse_client_pak: Received EAPOL packet from d8b3.7759.0488
010760: Jan  5 16:26:09.656 AZT: EAPOL pak dump rx
010761: Jan  5 16:26:09.656 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0009
010762: Jan  5 16:26:09.656 AZT: EAP code: 0x2  id: 0x1  length: 0x0009 type: 0x1
0B060D50:                   01000009 02010009          ........
0B060D60: 01746573 74                          .test
010763: Jan  5 16:26:09.660 AZT: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,CLIENT_REPLY) for d8b3.7759.0488
010764: Jan  5 16:26:09.660 AZT: dot11_auth_dot1x_send_response_to_server: Sending client d8b3.7759.0488 data to server
010765: Jan  5 16:26:09.660 AZT: dot11_auth_dot1x_send_response_to_server: Started timer server_timeout 60 seconds
010766: Jan  5 16:26:09.664 AZT: RADIUS/ENCODE(00000198):Orig. component type = DOT11
010767: Jan  5 16:26:09.664 AZT: RADIUS:  AAA Unsupported Attr: ssid              [282] 8
010768: Jan  5 16:26:09.664 AZT: RADIUS:   74 6F 79 73 6F 6E                                [toyson]
010769: Jan  5 16:26:09.664 AZT: RADIUS:  AAA Unsupported Attr: interface         [175] 3
010770: Jan  5 16:26:09.664 AZT: RADIUS:   36                                               [6]
010771: Jan  5 16:26:09.664 AZT: RADIUS(00000198): Config NAS IP: 192.168.16.49
010772: Jan  5 16:26:09.664 AZT: RADIUS/ENCODE(00000198): acct_session_id: 408
010773: Jan  5 16:26:09.664 AZT: RADIUS(00000198): Config NAS IP: 192.168.16.49
010774: Jan  5 16:26:09.664 AZT: RADIUS(00000198): sending
010775: Jan  5 16:26:09.664 AZT: RADIUS(00000198): Send Access-Request to 162.168.16.49:1645 id 1645/3, len 133
010776: Jan  5 16:26:09.664 AZT: RADIUS:  authenticator BF 69 DD DF 89 1F C6 FB - EF EC 12 EB C5 3F 3A CD
010777: Jan  5 16:26:09.664 AZT: RADIUS:  User-Name           [1]   6   "test"
010778: Jan  5 16:26:09.664 AZT: RADIUS:  Framed-MTU          [12]  6   1400
010779: Jan  5 16:26:09.664 AZT: RADIUS:  Called-Station-Id   [30]  16  "0019.3075.e660"
010780: Jan  5 16:26:09.664 AZT: RADIUS:  Calling-Station-Id  [31]  16  "d8b3.7759.0488"
010781: Jan  5 16:26:09.668 AZT: RADIUS:  Service-Type        [6]   6   Login                     [1]
010782: Jan  5 16:26:09.668 AZT: RADIUS:  Message-Authenticato[80]  18
010783: Jan  5 16:26:09.668 AZT: RADIUS:   5B FA 47 07 0E E3 4B 71 7F 60 6E 4E 91 37 84 A6  [[?G???Kq?`nN?7??]
010784: Jan  5 16:26:09.668 AZT: RADIUS:  EAP-Message         [79]  11
010785: Jan  5 16:26:09.668 AZT: RADIUS:   02 01 00 09 01 74 65 73 74                       [?????test]
010786: Jan  5 16:26:09.668 AZT: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
010787: Jan  5 16:26:09.668 AZT: RADIUS:  NAS-Port            [5]   6   661
010788: Jan  5 16:26:09.668 AZT: RADIUS:  NAS-Port-Id         [87]  5   "661"
010789: Jan  5 16:26:09.668 AZT: RADIUS:  NAS-IP-Address      [4]   6   192.168.16.49
010790: Jan  5 16:26:09.668 AZT: RADIUS:  Nas-Identifier      [32]  11  "router871"
010791: Jan  5 16:26:14.501 AZT: RADIUS: Retransmit to (162.168.16.49:1645,1646) for id 1645/3
router871#
010792: Jan  5 16:26:19.018 AZT: RADIUS: Retransmit to (162.168.16.49:1645,1646) for id 1645/3
router871#
010793: Jan  5 16:26:23.739 AZT: RADIUS: Retransmit to (162.168.16.49:1645,1646) for id 1645/3
router871#
010794: Jan  5 16:26:28.700 AZT: RADIUS: Fail-over to (162.168.16.49:1812,1813) for id 1645/3
router871#
010795: Jan  5 16:26:33.629 AZT: RADIUS: Retransmit to (162.168.16.49:1812,1813) for id 1645/3
router871#
010796: Jan  5 16:26:38.494 AZT: RADIUS: Retransmit to (162.168.16.49:1812,1813) for id 1645/3
router871#
010797: Jan  5 16:26:39.794 AZT: dot11_auth_parse_client_pak: Received EAPOL packet from d8b3.7759.0488
010798: Jan  5 16:26:39.794 AZT: EAPOL pak dump rx
010799: Jan  5 16:26:39.794 AZT: EAPOL Version: 0x1  type: 0x1  length: 0x0000
0AD053D0:                   01010000                   ....
010800: Jan  5 16:26:39.798 AZT: dot11_auth_dot1x_run_rfsm: Executing Action(SERVER_WAIT,EAP_START) for d8b3.7759.0488
010801: Jan  5 16:26:39.798 AZT: dot11_auth_dot1x_ignore_event: Ignore event: do nothing
router871#
010802: Jan  5 16:26:43.007 AZT: RADIUS: Retransmit to (162.168.16.49:1812,1813) for id 1645/3
router871#
010803: Jan  5 16:26:47.336 AZT: RADIUS: No response from (162.168.16.49:1812,1813) for id 1645/3
010804: Jan  5 16:26:47.336 AZT: RADIUS/DECODE: No response from radius-server; parse response; FAIL
010805: Jan  5 16:26:47.336 AZT: RADIUS/DECODE: Case error(no response/ bad packet/ op decode);parse response; FAIL
010806: Jan  5 16:26:47.336 AZT: dot11_auth_dot1x_parse_aaa_resp: Received server response: FAIL
010807: Jan  5 16:26:47.336 AZT: dot11_auth_dot1x_parse_aaa_resp: found eap pak in server response
010808: Jan  5 16:26:47.336 AZT: Client d8b3.7759.0488 failed: EAP reason 1
010809: Jan  5 16:26:47.336 AZT: dot11_auth_dot1x_parse_aaa_resp: Failed client d8b3.7759.0488 with aaa_req_status_detail 1
010810: Jan  5 16:26:47.336 AZT: dot11_auth_dot1x_run_rfsm: Executing Action(SERVER_WAIT,SERVER_FAIL) for d8b3.7759.0488
010811: Jan  5 16:26:47.336 AZT: dot11_auth_dot1x_send_response_to_client: Forwarding server message to client d8b3.7759.0488
010812: Jan  5 16:26:47.336 AZT: EAPOL pak dump tx
010813: Jan  5 16:26:47.336 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0004
010814: Jan  5 16:26:47.336 AZT: EAP code: 0x4  id: 0x1  length: 0x0004
0B060710:                   01000004 04010004          ........
0B060720:
010815: Jan  5 16:26:47.340 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010816: Jan  5 16:26:47.340 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010817: Jan  5 16:26:47.340 AZT: dot11_auth_dot1x_send_response_to_client: Started timer client_timeout 30 seconds
010818: Jan  5 16:26:47.340 AZT: dot11_auth_dot1x_send_client_fail: Authentication failed for d8b3.7759.0488
010819: Jan  5 16:26:47.340 AZT: dot11_auth_send_msg:  sending data to requestor status 0
010820: Jan  5 16:26:47.340 AZT: dot11_auth_send_msg: client FAILED to authenticate d8b3.7759.0488, node_type 64 for application 0x1
router871#
010821: Jan  5 16:26:47.340 AZT: dot11_auth_delete_client_entry: d8b3.7759.0488 is deleted for application 0x1
010822: Jan  5 16:26:47.344 AZT: %DOT11-7-AUTH_FAILED: Station d8b3.7759.0488 Authentication failed
010823: Jan  5 16:26:47.972 AZT: dot11_auth_add_client_entry: Create new client d8b3.7759.0488 for application 0x1
010824: Jan  5 16:26:47.972 AZT: dot11_auth_initialize_client: d8b3.7759.0488 is added to the client list for application 0x1
010825: Jan  5 16:26:47.972 AZT: dot11_auth_add_client_entry: req->auth_type 0
010826: Jan  5 16:26:47.972 AZT: dot11_auth_add_client_entry: auth_methods_inprocess: 2
010827: Jan  5 16:26:47.972 AZT: dot11_auth_add_client_entry: eap list name: eap-methods
010828: Jan  5 16:26:47.976 AZT: dot11_run_auth_methods: Start auth method EAP or LEAP
010829: Jan  5 16:26:47.976 AZT: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
010830: Jan  5 16:26:47.976 AZT: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to d8b3.7759.0488
010831: Jan  5 16:26:47.976 AZT: EAPOL pak dump tx
010832: Jan  5 16:26:47.976 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0031
010833: Jan  5 16:26:47.976 AZT: EAP code: 0x1  id: 0x1  length: 0x0031 type: 0x1
010834: Jan  5 16:26:47.996 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010835: Jan  5 16:26:47.996 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010836: Jan  5 16:26:47.996 AZT: dot11_auth_dot1x_send_id_req_to_client: Client d8b3.7759.0488 timer started for 30 seconds
010837: Jan  5 16:26:47.996 AZT: dot11_auth_client_abort: Received abort request for client d8b3.7759.0488
010838: Jan  5 16:26:47.996 AZT: dot11_auth_client_abort: Aborting client d8b3.7759.0488 for application 0x1
router871#
010839: Jan  5 16:26:47.996 AZT: dot11_auth_delete_client_entry: d8b3.7759.0488 is deleted for application 0x1
router871#
010840: Jan  5 16:26:58.634 AZT: dot11_auth_add_client_entry: Create new client d8b3.7759.0488 for application 0x1
010841: Jan  5 16:26:58.634 AZT: dot11_auth_initialize_client: d8b3.7759.0488 is added to the client list for application 0x1
010842: Jan  5 16:26:58.638 AZT: dot11_auth_add_client_entry: req->auth_type 0
010843: Jan  5 16:26:58.638 AZT: dot11_auth_add_client_entry: auth_methods_inprocess: 2
010844: Jan  5 16:26:58.638 AZT: dot11_auth_add_client_entry: eap list name: eap-methods
010845: Jan  5 16:26:58.638 AZT: dot11_run_auth_methods: Start auth method EAP or LEAP
010846: Jan  5 16:26:58.638 AZT: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
010847: Jan  5 16:26:58.638 AZT: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to d8b3.7759.0488
010848: Jan  5 16:26:58.638 AZT: EAPOL pak dump tx
010849: Jan  5 16:26:58.638 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0031
010850: Jan  5 16:26:58.638 AZT: EAP code: 0x1  id: 0x1  length: 0x0031 type: 0x1
0B060710:                   01000031 01010031          ...1...1
0B060720: 01006E65 74776F72 6B69643D 746F7973  ..networkid=toys
0B060730: 6F6E7067 2C6E6173 69643D72 6F757465  onpg,nasid=route
0B060740: 72383731 2C706F72 7469643D 30        r871,portid=0
010851: Jan  5 16:26:58.658 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010852: Jan  5 16:26:58.658 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010853: Jan  5 16:26:58.658 AZT: dot11_auth_dot1x_send_id_req_to_client: Client d8b3.7759.0488 timer started for 30 seconds
010854: Jan  5 16:27:01.603 AZT: dot11_auth_client_abort: Received abort request for client d8b3.7759.0488
010855: Jan  5 16:27:01.603 AZT: dot11_auth_client_abort: Aborting client d8b3.7759.0488 for application 0x1
010856: Jan  5 16:27:01.603 AZT: dot11_auth_delete_client_entry: d8b3.7759.0488 is deleted for application 0x1
010857: Jan  5 16:27:02.179 AZT: %SEC-6-IPACCESSLOGP: list ingress-filter denied tcp 32.42.41.254(57443) -> 72.201.117.84(59652), 1 packet
010858: Jan  5 16:27:02.179 AZT: %SEC-6-IPACCESSLOGP: list egress-filter denied tcp 22.3.184.118(0) -> 74.125.53.188(0), 4 packets
010859: Jan  5 16:27:12.261 AZT: dot11_auth_add_client_entry: Create new client d8b3.7759.0488 for application 0x1
010860: Jan  5 16:27:12.261 AZT: dot11_auth_initialize_client: d8b3.7759.0488 is added to the client list for application 0x1
010861: Jan  5 16:27:12.261 AZT: dot11_auth_add_client_entry: req->auth_type 0
010862: Jan  5 16:27:12.261 AZT: dot11_auth_add_client_entry: auth_methods_inprocess: 2
010863: Jan  5 16:27:12.261 AZT: dot11_auth_add_client_entry: eap list name: eap-methods
010864: Jan  5 16:27:12.261 AZT: dot11_run_auth_methods: Start auth method EAP or LEAP
010865: Jan  5 16:27:12.261 AZT: dot11_auth_dot1x_start: in the dot11_auth_dot1x_start
010866: Jan  5 16:27:12.261 AZT: dot11_auth_dot1x_send_id_req_to_client: Sending identity request to d8b3.7759.0488
010867: Jan  5 16:27:12.261 AZT: EAPOL pak dump tx
010868: Jan  5 16:27:12.261 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0031
010869: Jan  5 16:27:12.261 AZT: EAP code: 0x1  id: 0x1  length: 0x0031 type: 0x1
0B060FD0:                   01000031 01010031          ...1...1
0B060FE0: 01006E65 74776F72 6B69643D 746F7973  ..networkid=toys
0B060FF0: 6F6E7067 2C6E6173 69643D72 6F757465  onpg,nasid=route
0B061000: 72383731 2C706F72 7469643D 30        r871,portid=0
010870: Jan  5 16:27:12.285 AZT: dot11_auth_send_msg:  sending data to requestor status 1
010871: Jan  5 16:27:12.285 AZT: dot11_auth_send_msg: Sending EAPOL to requestor
010872: Jan  5 16:27:12.285 AZT: dot11_auth_dot1x_send_id_req_to_client: Client d8b3.7759.0488 timer started for 30 seconds
010873: Jan  5 16:27:12.293 AZT: dot11_auth_parse_client_pak: Received EAPOL packet from d8b3.7759.0488
010874: Jan  5 16:27:12.293 AZT: EAPOL pak dump rx
010875: Jan  5 16:27:12.293 AZT: EAPOL Version: 0x1  type: 0x0  length: 0x0009
010876: Jan  5 16:27:12.293 AZT: EAP code: 0x2  id: 0x1  length: 0x0009 type: 0x1
0AD05290:                   01000009 02010009          ........
0AD052A0: 01746573 74                          .test
010877: Jan  5 16:27:12.301 AZT: dot11_auth_dot1x_run_rfsm: Executing Action(CLIENT_WAIT,CLIENT_REPLY) for d8b3.7759.0488
010878: Jan  5 16:27:12.301 AZT: dot11_auth_dot1x_send_response_to_server: Sending client d8b3.7759.0488 data to server
010879: Jan  5 16:27:12.301 AZT: dot11_auth_dot1x_send_response_to_server: Started timer server_timeout 60 seconds
010880: Jan  5 16:27:12.301 AZT: RADIUS/ENCODE(0000019B):Orig. component type = DOT11
010881: Jan  5 16:27:12.305 AZT: RADIUS:  AAA Unsupported Attr: ssid              [282] 8
010882: Jan  5 16:27:12.305 AZT: RADIUS:   74 6F 79 73 6F 6E                                [toyson]
010883: Jan  5 16:27:12.305 AZT: RADIUS:  AAA Unsupported Attr: interface         [175] 3
010884: Jan  5 16:27:12.305 AZT: RADIUS:   36                                               [6]
010885: Jan  5 16:27:12.305 AZT: RADIUS(0000019B): Config NAS IP: 192.168.16.49
010886: Jan  5 16:27:12.305 AZT: RADIUS/ENCODE(0000019B): acct_session_id: 411
010887: Jan  5 16:27:12.305 AZT: RADIUS(0000019B): Config NAS IP: 192.168.16.49
010888: Jan  5 16:27:12.305 AZT: RADIUS(0000019B): sending
010889: Jan  5 16:27:12.305 AZT: RADIUS(0000019B): Send Access-Request to 162.168.16.49:1645 id 1645/4, len 133
010890: Jan  5 16:27:12.305 AZT: RADIUS:  authenticator 6F 6C 63 31 88 DE 30 A2 - C2 06 12 EB 50 A3 53 36
010891: Jan  5 16:27:12.305 AZT: RADIUS:  User-Name           [1]   6   "test"
010892: Jan  5 16:27:12.305 AZT: RADIUS:  Framed-MTU          [12]  6   1400
010893: Jan  5 16:27:12.305 AZT: RADIUS:  Called-Station-Id   [30]  16  "0019.3075.e660"
010894: Jan  5 16:27:12.305 AZT: RADIUS:  Calling-Station-Id  [31]  16  "d8b3.7759.0488"
010895: Jan  5 16:27:12.305 AZT: RADIUS:  Service-Type        [6]   6   Login                     [1]
010896: Jan  5 16:27:12.305 AZT: RADIUS:  Message-Authenticato[80]  18
010897: Jan  5 16:27:12.305 AZT: RADIUS:   9D D5 62 1A 38 13 94 30 3A 43 D7 A4 AE A4 43 64  [??b?8??0:C????Cd]
010898: Jan  5 16:27:12.305 AZT: RADIUS:  EAP-Message         [79]  11
010899: Jan  5 16:27:12.305 AZT: RADIUS:   02 01 00 09 01 74 65 73 74                       [?????test]
010900: Jan  5 16:27:12.305 AZT: RADIUS:  NAS-Port-Type       [61]  6   802.11 wireless           [19]
010901: Jan  5 16:27:12.305 AZT: RADIUS:  NAS-Port            [5]   6   664
010902: Jan  5 16:27:12.309 AZT: RADIUS:  NAS-Port-Id         [87]  5   "664"
010903: Jan  5 16:27:12.309 AZT: RADIUS:  NAS-IP-Address      [4]   6   192.168.16.49
010904: Jan  5 16:27:12.309 AZT: RADIUS:  Nas-Identifier      [32]  11  "router871"
010905: Jan  5 16:27:16.642 AZT: RADIUS: Retransmit to (162.168.16.49:1645,1646) for id 1645/4
i am also getting the login prompt for a user name or password
1624
