Bronze
Cisco 877 wireless password
Dear All ,
I configure the below on my Cisco877 router , I can connect to wireless but no password authentication .But when i change authentication method it doesn't connect .
The below is my config. with this i can connect, but no password
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 30
encryption vlan 1 mode ciphers wep40
ssid Shekkeer
    authentication open
    guest-mode
    wpa-psk ascii 0 0125345235
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
bridge-group 1
bridge 1 protocol ieee
bridge 1 route ip
Haris P
Re: Cisco 877 wireless password
replace
with
encryption vlan 1 mode ciphers tkip
WPA goes with tkip encryption, not wep.
Nicolas
Don't forget to rate answers that you find useful
Bronze
Dear Nicholas,
I tried the command you specified ,but it is still connecting without
any password ? Any Clues
The below is my runnning config
no ip address
ssid Shekkeer
authentication open
guest-mode
wpa-psk ascii 0 0102038989
ssid Test
authentication open
wpa-psk ascii 0 cisco123
36.0 48.0 54.0
station-role root
bridge-group 1
Shekkeer(config-if-ssid)#authentication key-management wpa
Error: Encryption mode cipher is not configured
Yes I forgot one command actually :
To be typed under your SSID configuration.
That should definitely work then.
Nicolas
Bronze
Dear Nicholas ,
I already tried that command
#interface Dot11Radio0
ssid Test
When I added Encription cipher ,it doesn't connect with the ssid
password ..I dont know what's happening
It's a small "cosmetic" problem I guess.
Because your ssid is in vlan 1 you should replace "encryption vlan 1 mode ciphers tkip" with  "encryption mode ciphers tkip"
Then it should allow you to go for "key-management wpa"
Nicolas
if you configure the below command
"encryption vlan 1 mode ciphers tkip" then under the SSID you need to map the VLA Nas well.. that is..
dot11 ssid
vlan 1
auth open
So, my wild guess.. can we reconfigure the same from the scratch? by deleting the SSID and then reconfiguring..
Surendra
and also make sure.. in autonomous.. its as simple as this.. ONE SSID : ONE VLAN mapping
Surendra
Bronze
It worked with below config...Thanks everyone for your help
Im, posting the config. I hope it will help some one in future
bridge irb
no ip address
ssid TEST
    authentication open
    guest-mode
    wpa-psk ascii 0 0102058745
54.0
station-role root
bridge-group 1
interface Vlan1
no ip address
ip nat inside
ip virtual-reassembly
bridge-group 1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 102 interface Dialer1 overload
bridge 1 route ip
1436
