Cisco 877W wireless speed issues
googloo420
Hi All,
I have Cisco 877, haivng low spped over inbuilt AP. I have tested it with same laptop with eccelent signal strength and qualiy.
Spped test results:  UL            DL
Over ethernet:      0.84Mbps     10.22Mbps
Over Wifi    :        0.13Mbps     0.15Mbps
Any ideas or suggestions ?
Scott Fella
Can you try using iperf and only testing in your local LAN. So like pc to pc then pc to wireless.
-Scott
fbarboza
Level 4
Level 4
When the issue occurs please capture the show dot11 asso all-clinet, also how many wireless clients are connected to the AP module at the same time the issue occurs.
fbarboza
We are preforming isolation test at the moment therefore wifi is not in production and connected to only 1 host.
ap#sh dot11 associations
802.11 Client Stations on Dot11Radio0:
SSID [CISCOWIFI] :
MAC Address    IP address      Device        Name            Parent         State
40a6.d9f0.4a40 192.168.61.6    unknown       -               self           Assoc
ap#sh dot11 associations all
ap#sh dot11 associations all-client
Address           : 40a6.d9f0.4a40     Name             : NONE
IP Address        : 192.168.61.6       Interface        : Dot11Radio 0
Device            : unknown            Software Version : NONE
CCX Version       : NONE               Client MFP       : Off
State             : Assoc              Parent           : self
SSID              : CISCOWIFI
VLAN              : 3
Hops to Infra     : 1                  Association Id   : 1
Clients Associated: 0                  Repeaters associated: 0
Tunnel Address    : 0.0.0.0
Key Mgmt type     : WPA PSK            Encryption       : TKIP
Current Rate      : 54.0               Capability       : WMM ShortHdr ShortSlot
Supported Rates   : 54.0
Voice Rates       : disabled           Bandwidth        : 20 MHz
Signal Strength   : -56  dBm           Connected for    : 828 seconds
Signal to Noise   : 30  dB            Activity Timeout : 60 seconds
Power-save        : On                 Last Activity    : 0 seconds ago
Apsd DE AC(s)     : NONE
Packets Input     : 10168              Packets Output   : 12868
Bytes Input       : 1917377            Bytes Output     : 16160162
Duplicates Rcvd   : 0                  Data Retries     : 691
Decrypt Failed    : 0                  RTS Retries      : 0
MIC Failed        : 0                  MIC Missing      : 0
Packets Redirected: 0                  Redirect Filtered: 0
Session timeout   : 0 seconds
Reauthenticate in : never
ap#
ap#sh ver
Cisco IOS Software, AP801 Software (AP801-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 16-Sep-09 18:59 by prod_rel_team
ROM: Bootstrap program is AP801 boot loader
BOOTLDR: AP801 Boot Loader (AP801-BOOT-M) Version 12.4(23c)JX, RELEASE SOFTWARE (fc1)
ap uptime is 4 days, 6 hours, 5 minutes
System image file is "flash:/ap801-k9w7-mx.124-21a.JA1/ap801-k9w7-mx.124-21a.JA1"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AP801GN-A-K9         (PowerPC 8343) processor (revision B0) with 49142K/16384K bytes of memory.
Processor board ID FGL15392021
PowerPC 8343 CPU at 400Mhz, revision number 0x0031
Last reset from power-on
1 Gigabit Ethernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 64:00:F1:78:13:B8
Part Number                          : 73-11027-11
PCA Assembly Number                  : 800-28807-11
PCA Revision Number                  : B0
PCB Serial Number                    : FOC14494Y6D
Top Assembly Part Number             : 800-29560-05
Top Assembly Serial Number           : FGL15392021
Top Revision Number                  : C0
Product/Model Number                 : AP801GN-A-K9
Configuration register is 0xF
ap#
Any feedback?
googloo420
Thanks folks
I will re-commence testing over the weekend.
fbarboza
only one laptop connected while conducting tests
