03-28-2009 04:48 AM - edited 07-03-2021 05:22 PM
Hi guys. iam new to the aeronet 1131ag AP. it had an association with a controller wich is not there at all.My problem is, how do i reset the configs to default.the other thing is that i cannot configure it, its indicating an error messege ERROR!!! Command is disabled.i tried looking on the website and cant get any info
03-28-2009 03:38 PM
To set the AP to factory default, you need to run the Autonomous IOS (aIOS). Follow the documentations below for the procedures:
Password Recovery Procedure for the Cisco Aironet Equipment
Hope this helps.
03-28-2009 08:29 PM
Console into the AP then follow the following steps:
First, check the flash:
lap_1131#dir
Directory of flash:/
2 -rwx 279 May 09 2008 11:52:20 +00:00 env_vars
4 -rwx 6168 May 09 2008 11:52:20 +00:00 private-multiple-fs
6 drwx 256 May 09 2008 11:49:05 +00:00 c1130-k9w8-mx.124-3g.JA2
5 drwx 128 Mar 01 2002 00:03:43 +00:00 c1130-rcvk9w8-mx
15998976 bytes total (10716672 bytes free)
Then delete the LWAPP image:
lap_1131#delete /r /f flash:/c11310-k9w8-mx.124-3g.JA2
Not the one the has rcv in it!!!!!!
Thirdly reload the AP:
lap_1131#reload
Then issue a clear lwapp private-config
You'll end up with a clear AP.
