10-08-2014 04:51 PM - edited 07-05-2021 01:41 AM
Hi all,
I've got 2x 1142N access points. Both are running autonomous software.
they're both connected to Cisco 3750G's (SW1 and SW2) in the following way:
SW1 - AP1 >>>> AP2-SW2
I'm trying to accomplish 2 things here:
- The AP's need to bridge the two wired LAN's on the 5Ghz radio (dot11radio1)
- The AP's should try to advertise the same WLAN for Clients on the 2.4ghz radio (dot11radio0).
What works?
- The AP's bridge on the 5Ghz radio, this works fine. Clients can connect to devices across the bridge.
- Wireless clients can connect to fine to the wlan-client ssid on AP1. At AP2 the Dot11radio0 refuses to come up with different errors:
*Mar 1 07:10:50.825: %DOT11-4-NO_VALID_INFRA_SSID: No infrastructure SSID configured. Dot11Radio0 not started.
03:39:22: DOT11 EVENT:disc_start:Could not configure the radio.
*Mar 1 07:10:50.825: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
03:40:22: DOT11 EVENT:disc_config: root set device to 4D
*Mar 1 07:12:01.902: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: No Response
*Mar 1 07:12:06.912: %DOT11-4-CANT_ASSOC: Interface Dot11Radio0, cannot associate: Rcvd response from 64d9.896d.cc80 channel 13 2928
I'm using the configuration as per below; anybody got a clue what I'm doing wrong here?
Configuration:
! AP1:
dot11 syslog
dot11 ssid backhaul
authentication open
dot11 ssid wlan-client
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 0 test
bridge irb
interface Dot11Radio0
description ; 2.4 Ghz radio
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid wlan-client
antenna gain 0
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid backhaul
antenna gain 0
no dfs band block
channel dfs
station-role root bridge
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
! AP2:
dot11 ssid backhaul
authentication open
infrastructure-ssid
authentication open
guest-mode
infrastructure-ssid
wpa-psk ascii 7 0830747B2C3B34003F3A5A361E032A23313617401711212463
bridge irb
no ip address
no ip route-cache
ssid wlan-client
antenna gain 0
station-role non-root wireless-clients
bridge-group 1
no ip address
no ip route-cache
ssid backhaul
antenna gain 0
station-role workgroup-bridge
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
no ip route-cache
Solved! Go to Solution.
10-10-2014 06:35 AM
on AP 2 under the Radio 0 it should be "station-role root", not non-root. Sorry I missed that in the config earlier.
HTH,
Steve
10-09-2014 10:42 AM
On AP 2 you need to remove the Infrastructure-ssid command under the wlan-client SSID. That command is for telling the AP that it uses that SSID to connect to another radio.
HTH,
Steve
10-09-2014 12:34 PM
Hi Steve,
I did that. Then i get the following error:
My SSID configuration is as follows now:
AP2:
dot11 ssid wlan-bb
authentication open
infrastructure-ssid
dot11 ssid wlan-hs
authentication open
guest-mode
Do you know how to explain that error?
AP1:
dot11 ssid wlan-bb
authentication open
infrastructure-ssid
dot11 ssid wlan-hs
authentication open
guest-mode
10-10-2014 06:35 AM
HTH,
Steve
10-12-2014 04:58 PM
That was it indeed Steve! Many thanks, it works like a charm now :)
