Cisco AIR-SAP2602I-E-K9 controller joining
We having 8 AIR-SAP2602I-E-K9 and one cisco 2504 wireless controller with image 7.4.100.0 .Is these access points can join the controller automatically or either it need a image conversion.
Which image version is compatible
This is the current image version running in Access point
VIP Purple
Hi Sajad,These AP need the 7
Hi Sajad,
These AP need the 7.2.110.0 image on WLC and you have higher then this.
So dont worry they will join to WLC.
Make sure AP get the IP address and there is one method configured to findout the WLC.
Dont forget to rate helpful posts
Bronze
Please refer the following
Please refer the following matrix.
Table 1 Software Support for Access Points
Access Points
First Support
Last Support
700 Series
AIR-CAP702I-x-K9
7.5.102.0
AIR-CAP702I-xK910
7.5.102.0
700W Series
AIR-CAP702W-x-K9
7.6.120.0
1000 Series
AIR-AP1010
3.0.100.0
4.2.209.0
AIR-AP1020
3.0.100.0
4.2.209.0
AIR-AP1030
3.0.100.0
4.2.209.0
Airespace AS1200
4.0
AIR-LAP1041N
7.0.98.0
AIR-LAP1042N
7.0.98.0
1100 Series
AIR-LAP1121
4.0.155.0
7.0.x
1130 Series
AIR-LAP1131
3.1.59.24
1140 Series
AIR-LAP1141N
5.2.157.0
AIR-LAP1142N
5.2.157.0
1220 Series
AIR-AP1220A
3.1.59.24
7.0.x
AIR-AP1220B
3.1.59.24
7.0.x
1230 Series
AIR-AP1230A
3.1.59.24
7.0.x
AIR-AP1230B
3.1.59.24
7.0.x
AIR-LAP1231G
3.1.59.24
7.0.x
AIR-LAP1232AG
3.1.59.24
7.0.x
1240 Series
AIR-LAP1242G
3.1.59.24
AIR-LAP1242AG
3.1.59.24
1250 Series
AIR-LAP1250
4.2.61.0
AIR-LAP1252G
4.2.61.0
AIR-LAP1252AG
4.2.61.0
1260 Series
AIR-LAP1261N
7.0.116.0
AIR-LAP1262N
7.0.98.0
1300 Series
AIR-BR1310G
4.0.155.0
7.0.x
1400 Series
Standalone Only
1600 Series
AIR-CAP1602I-x-K9
7.4.100.0
AIR-SAP1602I-x-K9
7.4.100.0
AIR-CAP1602E-x-K9
7.4.100.0
AP801
5.1.151.0
AP802
7.0.98.0
AP802H
7.3.101.0
2600 Series
AIR-CAP2602I-x-K9
7.2.110.0
AIR-SAP2602I-x-K9
7.2.110.0
AIR-CAP2602E-x-K9
7.2.110.0
AIR-SAP2602E-x-K9
7.2.110.0
2700 Series
AIR-CAP2702I-x-K9
7.6.120.0
AIR-CAP2702E- x-K9
7.6.120.0
3500 Series
AIR-CAP3501E
7.0.98.0
AIR-CAP3501I
7.0.98.0
AIR-CAP3502E
7.0.98.0
AIR-CAP3502I
7.0.98.0
AIR-CAP3502P
7.0.116.0
3600 Series
AIR-CAP3602I-x-K9
7.1.91.0
AIR-CAP3602I-xK910
7.1.91.0
AIR-CAP3602E-x-K9
7.1.91.0
AIR-CAP3602E-xK910
7.1.91.0
USC5101-AI-AIR-K9
7.6
3700 Series
AIR-CAP3702I
7.6
AIR-CAP3702E
7.6
AIR-CAP3702P
7.6
600 Series
AIR-OEAP602I
7.0.116.0
Note The Cisco 3600 Access Point was introduced in Release 7.1.91.0. If your network deployment uses Cisco 3600 Access Points with Release 7.1.91.0, we highly recommend that you upgrade to Release 7.2.103.0 or a later release.
1500 Mesh Series
AIR-LAP-1505
3.1.59.24
4.2.207.54M
AIR-LAP-1510
3.1.59.24
4.2.207.54M
1520 Mesh Series
AIR-LAP1522AG
-A and N: 4.1.190.1 or 5.2 or later1
All other reg. domains: 4.1.191.24M or 5.2 or later1
AIR-LAP1522HZ
AIR-LAP1522PC
AIR-LAP1522CM
7.0.116.0 or later.
AIR-LAP1524SB
-A, C and N: 6.0 or later
All other reg. domains: 7.0.116.0 or later.
AIR-LAP1524PS
-A: 4.1.192.22M or 5.2 or later1
1530
AIR-CAP1532I-x-K9
7.6
AIR-CAP1532E-x-K9
7.6
1550
AIR-CAP1552I-x-K9
7.0.116.0
AIR-CAP1552E-x-K9
7.0.116.0
AIR-CAP1552C-x-K9
7.0.116.0
AIR-CAP1552H-x-K9
7.0.116.0
AIR-CAP1552CU-x-K9
7.3.101.0
AIR-CAP1552EU-x-K9
7.3.101.0
1552S
AIR-CAP1552SA-x-K9
7.0.220.0
AIR-CAP1552SD-x-K9
7.0.220.0
correct answer
correct answer
VIP Purple
Hi Saad,Mark the question as
Hi Saad,
Mark the question as answerd, it may help others.
Sandeep is correct.  Also,
Sandeep is correct.  Also, since you posted a model type of an autonomous/"s"tandalone 2600 ("S"AP2602I), vs the lightweight/"C"apwap version (CAP2602I), you may need to validate the version of code running on the AP if it does not appear to be joining.
In your screenshot, the image file ap3g2-k9w"8" indicates a lightweight version ready to join your WLC.  If you find an ap3g2-k9w"7", this is the autonomous/standalone image and will not join a WLC without being converted to lightweight.
There are several threads on this process, such as this http://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
605
