cisco aironet 1100 weak signal with ipad2 iphone and blackberry
power.srvi
hi all,
in my company we have 40 cisco aironet 1100 without controller, the signal is good with laptops but is too weak with the iphone's ipads and blackberry.
Can some one help ?
regards
2 Accepted Solutions
johncaston_2
Sounds to me that it might be time to upgrade your AP's - they're obsolete b/g models.
Something like the 1142a/b/g/n would be good - 802.11n also improves transmission to non-802.11n devices
The other things that you might like to look at is the AP density, a good rule of thumb is 1 AP per 450m2 for data and 1x AP per 280m2 for voice
You should also look at disabling 1,2,5.5 and 11Mbps throughput (802.11b) as this slows down 802.11g communications
channel 2447
This tells you it is static.
Scott Fella
Sent from my iPhone
-Scott
12 Replies 12
johncaston_2
hi,
thank you for the reply,
i also changed the channel, in this compagny we have 60 ap, in the zone with the channels set to 1-7 there is no problem
but when i connect to the channel 13 with iphone 3gs and 4g i pad and blackberry the signal is so weak.
when i put channel 8 at the place of the channel 13 the signal becaumes more storng.
I will alsio try with the setting that you gave me.
Thank you again for the reply i will take you up to date.
regards
I don't know what country you have these AP's, but using channel 1, 6, and 11 is the norm. The iOS devices might not be able to use channel 13.
Scott Fella
Sent from my iPhone
-Scott
we are using this access point in north africa, he model is aironet 1100 version
version 12.3
and we are using channels 2,7,13
so the wireless network was designed buy another compagny, so can you send me a good documentation about designing wireless network, best practices too.
also the 60 ap are not managed buy an wireless controller, it is necessary to use a controller ? if yes have you a good model.
thanks
Well with the 1100's you are better off to migrate to newer AP's (capwap) and use a 5508-100. You can get a 5508-50 and a license for another 25 APs, but having two WLC is required for redundancy. If you look at basic wireless configuration, you would use channel 1, 6, and 11.
Scott Fella
Sent from my iPhone
-Scott
thanks
I would change channel 2 to channel 1, channel 7 to channel 6 and channel 13 to channel 11. Are the channels static or are they dynamic?
Scott Fella
Sent from my iPhone
-Scott
how can i know that the channels are dynamic or static ?
here is a configuration sample:
version 12.3
no service pad
service password-encryption
hostname xxxxxxxxxx
ip subnet-zero
no aaa new-model
dot11 ssid xxxxxxxxxxxxxx
   authentication open
   guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid xxxxxxxxxxxxxxx
short-slot-time
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
rts retries 100
packet retries 100
channel 2447
fragment-threshold 1000
station-role root
beacon period 2000
beacon dtim-period 50
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
channel 2447
Scott Fella
Sent from my iPhone
-Scott
thanks mr fella,
so its better to keep channels on static mode ?
I would say yes, especially if it was surveyed and the other company decided what channels to use where. Just modify the channels which I posted previously.
Scott Fella
Sent from my iPhone
-Scott
Most countries support channels 1-13 and some also support 14 (but not many).
You can use channels 2,7 and 13 but the norm is to use 1, 6 and 11 - either way you only end up with 3 non-overlapping channels. These channels refer to the centre frequencies and 802.11 is wide-band so it will use several adjacent frequencies too, i.e. channel 2 will still overlap channel 1, so there's nothing to be gained by using 2,7 and 13 - personal preference really
When installing a controller-based wireless solution I prefer to leave DCA (Dynamic Channel Assignment) and TPC (Transmit Power Controller) enabled (default), as this lets the controller determine the optimal channel and power settings and it makes the solution more adaptable to changes in the environment, not to mention it's easier to manage.
In situations where I have interference from a specific device, e.g. radio mics, I would fix the channel for the neighbouring AP's but still let the rest find the optimum settings (also helps with with coverage holes if an AP fails)
As to why you're getting weak signals on some devices, probably more related to lower radio power - I would begin with doing a wireless site survey with something like AirMagnet Surveyor to produce a heatmap and see what your coverage is like
Hope that helps
Cheers,
John
