Cisco Aironet 1200 - MIBS question
theodionys
firmware installed 123-8.JEB
I use NET-SNMP to take information from AP's database agent.
I want the following information:
client rates (Mbps) - the current rate of
every client connected to the access point. For example for 3 clients -> 1Mbps,5.5Mbps, 11Mbps
I have searched all the supported MIBS from Cisco's website but i cant find anything...
Do i miss something??
Can you help plz...
Best regards,
Theodoros Dionysiou
irisrios
Level 6
Level 6
There are no MIBs available > YOu can know the data rate from the client utility themselves.You can also use Protocol analyzer or link test on the client utility to know the data rates.
Hello again,
I have found what i needed.
CISCO-DOT11-ASSOCIATION-MY.my
Object : cDot11ClientCurrentTxRateSet
This object gives the information about the current rate that the access point sends data to the client.
I have tested this and it's correct.
