Cisco Aironet 1300 Series wireless birdge problem
first one, i'm sorry for my english.
I have a very big problem with the bridge. I can't configure the nonRoot bridge. It's not possible for me to turn on the radio. The software and hardware are always disable...
The SSID management is configured with the same SSID.
For the test, there isn't encryption.
thanks a lot for your help
G.Vincent
Bronze
Re: Cisco Aironet 1300 Series wireless birdge problem
the non-root bridge will always show the radio as down until it authenticates/associates with a root bridge this is normal. the radio is shown as down because the bridge link has not been establiehed, the radio is looking for the root bridge, once it discovers the root bridge and links up it's status will be changed to up.
what model 1310's do you have?
canyou share yyour config.
one trick you can use is to save the config on you root bridge and then apply it to your nonroot remembering to change the IP address and Role. this eliminates any typos causing your problem.
Bill
Bill
Thank you for your answer.
The root birdge is a 1310G-E-K9-R
Tne non root bridge is a 1310G-E-K9-R
To configure the bridge, I have followed the cisco documentation.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058f53e.shtml
The root configuration:
version 12.4
no service pad
service password-encryption
hostname ap
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
dot11 activity-timeout bridge default 1
dot11 ssid martinshotels
guest-mode
infrastructure-ssid
username Cisco password xxx
username administrator privilege 15 password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid martinshotels
station-role root bridge
distance 1
bridge-group 1
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.250 255.255.255.0
no ip route-cache
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
end
The non root configuration :
version 12.4
no service pad
hostname apNonRoot
aaa new-model
guest-mode
infrastructure-ssid
bridge irb
no ip address
no ip route-cache
ssid martinshotels
station-role non-root bridge
mobile station scan 2417
bridge-group 1
no ip address
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.168.0.251 255.255.255.0
no ip route-cache
ip http server
bridge 1 route ip
line con 0
line vty 0 4
end
Thanks a lot for your help
Bronze
two things
one your AP's require remote antennas the end of your part numnber K9-R the R indicates this model uses remote antennas there are two TNC connectors on he bottom next to to the Coax connection. you did not mention what remote antennas you are using, be part of your problem, antena alignment is critical.
two I do not see a channel set in your root configuration, so it is probably set to least congested channel, which is okay. Howevedr your non root is set to Scan Channel 2 (2417) by the Mobile station command. The mobile station is only used if you need your non root to roam between root AP's
number two is a problem that needs to be fixed. the non root should scan all channels looking for a root, the other option is to set them to the same channel
Bill
hi,
i have got the same problem and nothing works, every documents tell us it's easy, you do it and everythings works but no no no,
Can you help us please ??? have you resolve your problem ? if yes, how ?
sorry for my english but i'm french
thank you very much
If you have the same device that me. You need a external antennas.
Do the K9-R bridges also support an internal antenna?
In the radio configuration the default from factory is the internal antenna, you have yo manually select the external antenna and antenna gain.
Bronze
The Short answer is No
the -R suffix indicates remote antennas only
Bill
676
