Community Member
cisco aironet 1310G non_native vlan and dhcp
hi evrybody
i have problem with my cisco aironet 1310G
non-native vlan can not get(dynamicly)ip address from cisco aironet 1310G
this is all my configuration please can someone help me
ip dhcp excluded-address 20.20.20.20
ip dhcp excluded-address 20.0.0.0
ip dhcp excluded-address 30.0.0.0
ip dhcp excluded-address 30.30.30.30
ip dhcp excluded-address 10.0.0.0
ip dhcp excluded-address 10.0.0.10
ip dhcp excluded-address 10.1.0.0
ip dhcp excluded-address 10.1.0.10
ip dhcp pool d01
network 10.0.0.0 255.255.255.0
default-router 10.0.0.10
ip dhcp pool d02
network 20.0.0.0 255.255.255.0
default-router 20.20.20.20
ip dhcp pool d03
network 30.0.0.0 255.255.255.0
default-router 30.30.30.30
no aaa new-model
dot11 ssid vlan01
vlan 1
authentication open
dot11 ssid vlan02
vlan 2
authentication open
dot11 ssid vlan3
vlan 3
authentication open
username cisco password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
broadcast-key vlan 2 change 100
broadcast-key vlan 3 change 100
ssid vlan01
ssid vlan02
ssid vlan3
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root access-point
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
bridge-group 2 spanning-disabled
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 10.0.0.10 255.255.255.0
no ip route-cache
interface BVI2
ip address 20.20.20.20 255.255.255.0
no ip route-cache
interface BVI3
ip address 30.30.30.30 255.255.255.0
no ip route-cache
control-plane
bridge 1 priority 9000
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 priority 10000
bridge 2 protocol ieee
bridge 3 priority 3100
bridge 3 protocol ieee
line con 0
line vty 0 4
login local
end
Community Member
Re: cisco aironet 1310G non_native vlan and dhcp
Greetings,
It would appear that your DHCP scopes are wrong.
When the dhcp request comes in it wont find a DCHP pool because BVI2 and BVI3 do not match your scopes. The network statement doesn't match. From my guess of what you meant to specify you should have the scopes to the following:
ip dhcp pool d02
network 20.20.20.0 255.255.255.0
ip dhcp pool d03
network 30.30.30.0 255.255.255.0
These two network statements would match both your BVI's.
To verify that your the requests are not finding a DHCP scope you could use this command on the ap... 'debug ip dhcp server {events | packets | linkage}'
Community Member
hi friend
i did what you sugested but it is styl not working so plz find below the show run and debug ip dhcp server in ordr to help us thanks for all your suport
ip subnet-zero
ip dhcp excluded-address 20.0.0.20
ip dhcp excluded-address 30.0.0.30
ip dhcp pool d01
ip dhcp pool d02
default-router 20.0.0.20
ip dhcp pool d03
default-router 30.0.0.30
aaa new-model
dot11 ssid vlan01
vlan 1
authentication open
guest-mode
dot11 ssid vlan02
vlan 2
authentication open
dot11 ssid vlan03
vlan 3
authentication open
bridge irb
no ip address
no ip route-cache
ssid vlan01
ssid vlan02
ssid vlan03
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
no ip address
no ip route-cache
hold-queue 80 in
no ip route-cache
bridge-group 1
no ip route-cache
bridge-group 2
no ip route-cache
bridge-group 3
interface BVI1
no ip route-cache
interface BVI2
ip address 20.0.0.20 255.255.255.0
no ip route-cache
interface BVI3
ip address 30.0.0.30 255.255.255.0
ip helper-address 30.0.0.0
no ip route-cache
and debug ip dhcp server {events | packets | linkage}
*Mar 1 01:06:37.054: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 0011.a304.2b65 Reason: Sending station has left the BSS
*Mar 1 01:06:40.140: %DOT11-6-ASSOC: Interface Dot11Radio0, Station 0011.a304
.2b65 Associated KEY_MGMT[NONE]
531
