09-08-2014 02:29 PM - edited 07-05-2021 01:29 AM
Earlier this month Cisco released a new autonomous IOS for the 2700 and 3700 access-points. If I look at the release logs, they reference to a new 1700I access-point:
Support for Cisco Aironet 1700 Series access point
- This access point is built on 3x3:2(2.4GHz), 3x3:2(5GHz) MIMO technology, and comes with integrated antennas, and supports 802.11a,b,g,n,ac. This access point has both primary and secondary gigabit Ethernet ports. The primary port is gigabit Ethernet 0 and is the backhaul port. The primary port can be set as trunk port. The secondary port is gigabit Ethernet 1, and is the access port. You can configure the secondary port to a VLAN ID using the interface configuration command bridge multiple-port client-vlan vlan-id
- Supported model is 1700I
(http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ios/release/notes/rn-15-3-3.html)
Has anyone of you guys have some inside information about this new access-point?
09-08-2014 03:16 PM
1702I/1702E is coming. One of the guys here, Rasika, is beta testing the hardware and firmware.
09-08-2014 04:32 PM
I am doing beta for IOS-XE 3.7 which supports this AP model & some other features.
Unfortunately I do not have this AP model at my hand to tell you any specifics.
Rasika
10-02-2014 07:41 AM
Thanks for the information. Have you any ideas of the release date of a Prime Infrastructure Template.
We will try to deploy a few dozen of them. I think it will be easier with P.Infra
thanks in advance
Jean-Luc
09-23-2014 11:53 AM
It's orderable now.
AIR-CAP1702I-A-K9
- Ron
stndip.com
09-23-2014 12:10 PM
yes. It looks like 8.0.100.0 code introduced this new AP model support for AireOS controllers.
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Rasika
