Cisco Aironet 2600 connected to access point and internet but not to local resources
I have problem with Cisco Aironet 2600 Access Point and just wander if somebody could point me how to troubleshoot issue like that. Basically 8 months ago some users sometimes started to have problems with connectivity to servers (couple of) located in the same network with firewall and access point (SMB, RDP, ICMP). However they are getting access to internet through ASA firewall and connection to Access Point is working fine. User had to disconnect and connect over cable to get it working. Only some users were affected and no pattern in this (one day particular users is fie, next not). There were many different network adapters and systems (Windows 7, Windows8, IOS). Eventually I replaced Access point to new one (same model) and everything have been working fine for 5 months and today the same problem againL
Cable connection works ok all the time. Any idea what it could be? No firewall or router between AP and the network.
Thank you.
Config below:
Building configuration...
Current configuration : 3776 bytes
! Last configuration change at 15:39:54 UTC Thu Apr 24 2014
! NVRAM config last updated at 15:14:53 UTC Thu Apr 24 2014
version 15.2
no service pad
service password-encryption
hostname AP
logging rate-limit console 9
enable secret 5 secret
no aaa new-model
no ip routing
ip domain name netwotk.local
dot11 syslog
dot11 ssid WiFi-Network
   authentication open
   authentication key-management wpa version 2
   guest-mode
   wpa-psk ascii 7 DHFDIS2323JFdF335353534
dot11 network-map
crypto pki trustpoint TP-self-signed-579476643
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-579476643
 revocation-check none
 rsakeypair TP-self-signed-579476643
crypto pki certificate chain TP-self-signed-579476643
 certificate self-signed 01
        quit
username user privilege 15 secret 5 $$J£KHSHFK£HK$H£KHFHEHFefef
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers aes-ccm tkip
 ssid WiFi-Network
 antenna gain 0
 stbc
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
 channel 2462
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 encryption mode ciphers tkip
 ssid WiFi-Network
 antenna gain 0
 no dfs band block
 stbc
 channel width 40-above
 channel 5240
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 bridge-group 1
interface BVI1
 ip address 192.168.1.240 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.1.254
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
no cdp run
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
VIP Purple
Hi,I would do the config like
I would do the config like below as WPA2 always go with AES & not TKIP. Also I would not set CH statically & let it be dynamic.
 no encryption mode ciphers aes-ccm tkip
 channel least-congested
 no encryption mode ciphers tkip
 channel dfs
Still problem persist, I would check the software version used in the previous 2600(may be old IOS, but could be stable). if it is different (like 12.x) I would go with that & see.
Rasika
**** Pls rate all useful responses ****
Check your ARP entries on
Check your ARP entries on both your wireless client and on the server you can't connect to.
Do they exist and are they correct?
Andrew,Thank you for your
Andrew,
Thank you for your reply.
ARP entries don't exist (only for default gateway)
What version of code are you
What version of code are you running "sh ver".
How many clients are associated "show dot11 assoc".
What does the Ethernet interface look like - any errors: "show int gi0".
Hi Andrew,Thank you for your
Hi Andrew,
Thank you for your reply, please see below:
AP1#sh ver
Cisco IOS Software, C3600 Software (AP3G2-K9W7-M), Version 15.2(2)JA, RELEASE SO        FTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 23-Aug-12 02:59 by prod_rel_team
ROM: Bootstrap program is C3600 boot loader
BOOTLDR: C3600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JA1, RELEASE SO        FTWARE (fc1)
AP1 uptime is 19 weeks, 3 days, 20 hours, 57 minutes
System restarted at 11:21:39 UTC Thu Dec 12 2013
System image file is "flash:/ap3g2-k9w7-mx.152-2.JA/ap3g2-k9w7-xx.152-2.JA"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-SAP2602I-E-K9    (PowerPC) processor (revision A0) with 180214K/81920K        bytes of memory.
Processor board ID FCZ1743D00Z
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: E4:C7:22:8A:1C:A3
Part Number                          : 73-14588-02
PCA Assembly Number                  : 800-37899-01
PCA Revision Number                  : A0
PCB Serial Number                    : FOC17362Q7M
Top Assembly Part Number             : 800-38356-01
Top Assembly Serial Number           : FCZ1743D00Z
Top Revision Number                  : A0
Product/Model Number                 : AIR-SAP2602I-E-K9
Configuration register is 0xF
AP1#show dot11 assoc
802.11 Client Stations on Dot11Radio0:
SSID [Richmond-Network] :
MAC Address    IP address      Device        Name            Parent         Stat        e
0026.8290.e459 192.168.1.146   unknown       -               self           Asso        c
00db.df12.b29f 192.168.1.72    ccx-client    AP1     self           Asso        c
181e.b04d.f062 192.168.1.135   unknown       -               self           Asso        c
183d.a28f.02e8 192.168.1.142   ccx-client    AP1     self           Asso        c
400e.8534.9560 192.168.1.66    ccx-client    -               self           Asso        c
5472.4f4d.4e16 192.168.1.138   unknown       -               self           Asso        c
7018.8be2.60b0 192.168.1.140   ccx-client    -               self           Asso        c
7018.8be2.611f 192.168.1.68    ccx-client    -               self           Asso        c
a44e.31ae.8734 192.168.1.143   ccx-client    AP1     self           Asso        c
a888.0858.abba 192.168.1.71    unknown       -               self           Asso        c
b8f6.b1f2.18e4 192.168.1.145   unknown       -               self           Asso        c
c8f7.33ad.93cd 192.168.1.139   ccx-client    EMMA-TOSH       self           Asso        c
cc52.af5f.486a 192.168.1.70    unknown       -               self           Asso        c
802.11 Client Stations on Dot11Radio1:
3423.bada.be67 192.168.1.67    unknown       -               self           Asso        c
380f.4ac5.8ae8 192.168.1.151   unknown       -               self           Asso        c
54e4.3a89.2600 0.0.0.0         unknown       -               self           Asso        c
AP1#show int gi0
GigabitEthernet0 is up, line protocol is up
  Hardware is PowerPC Ethernet, address is e4c7.228a.1ca3 (bia e4c7.228a.1ca3)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 255/255, rxload 1/255
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is T
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output never, output hang never
  Input queue: 3/22852/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 75000 bits/sec, 10 packets/sec
  5 minute output rate 12000 bits/sec, 8 packets/sec
     458698827 packets input, 621337110 bytes, 0 no buffer
     Received 54198669 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     364073996 packets output, 3314222521 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Hello
Hello
You could solve the problem ??
Regards.
Rasika, Thank you for your
Rasika,
Thank you for your reply. I've tested settings above and they haven't helped. Unfortunately I don't have old AP so can't compare ISO version and I don't have support contract so can't download new one:-(
Hall of Fame Super Silver
When you make these changes
When you make these changes the Rasika provided, you need to also make sure you delete the profile from the client and create it again.
Please rate helpful post and Cisco Support Community will donate to Kiva
Scotty
-Scott
Hi Scott,I'm not sure how to
Hi Scott,
I'm not sure how to rate this as helpful, I gave 5 stars, is it what Cisco is looking fore to donate?
1007
