Cisco Aironet 350 and cordless phone
Cisco Aironet 350 802.11b card working with 3rd party wireless DSL router (LinkSys, D-link or Netgear) to establish VPN tunnel via Cisco VPN client. VPN session always get drop when using 9600 MHz cordless phone. Is there something between Cisco Aironet 350 card and 3rd party wireless DSL router? Or it is between Cisco Aironet 350 card and cordless phone?
Re: Cisco Aironet 350 and cordless phone
Ap350 works on the 2.4 Gig hz. freq. the phone in use should not have a significant effect on the AP.
Please install the Aironet Client Untility from the cisco web site and monitor the SNR ratio.
The signal strength on the ACU shows unchange while VPN session will drop every time the cordless phone is used to answer incoming call or dialing an outgoing call. This problem only happen dring wireless and VPN are in session.
Anonymous
N/A
Perhaps the DSL connection is being interrupted/disrupted when the telephone is in use. Could also be a bad DSL filter on that extension. Try using a corded phone to see if it's maybe not the cordless that's causing the problem.
118
