I got problem with the above device to worked properly with my laptop running OS XP.It did recognise the device,which i can configured and use it immediately.But once i reboot the comp the wireless cannot function ,even thought trying to re-configured does not help?
Further to the above,when i check under setting/control panel/network/property/configure/advance under the property box there is NO SSID.Could it be due to this
that way i unable to log in or maybe the wireless card faulty??
