Cisco Aironet 3600e LWAPP to Autonomous AP conversion
I recently erased all the files in the flash memory for a Cisco Aironet 3600e Access Point so that i could convert it from LWAPP IOS to Autonomous IOS.  The access point is booting to ROMMON mode i have tried to copy the IOS from a tftp server but every time i get a connection time out error. Could i have done something wrong to erase all the files in flash memory. What can i do to load the ios to the access point i have tride everthing but im getting the error below while using tftpd32
examining image...
DPAA Set for Independent Mode
DPAA_INIT = 0x0
%Error opening tftp://23.35.64.106/ap3g2-k9w7-152-2.JB.tar (connection timed out)ap:
Hall of Fame Super Gold
Please check the Windows Firewall in your TFTP server.
Re: Cisco Aironet 3600e LWAPP to Autonomous AP conversion
And you have to change the IOS file name and extension.
ap3g2-k9w7-152-2.JB.tar -> ap3g2-k9w7-tar.default
VIP Purple
Here is a example for how to do this conversion using AP mode button. This may be useful to you
http://mrncciew.com/2013/12/13/ap-conversion-using-mode-button/
Rasika
**** Pls rate all useful resposes *****
813
