02-26-2002 10:48 PM - edited 07-04-2021 10:59 PM
I think ive finally decided on what Radio to use for the ISP Services. I Have several (20+) Cellsites and am planning on using Sector Antennas at each cell for the Clients to connect to. I have a couple quick questions before I start ordering tomorrow.
1. What is the Frequency range per channel of both the 340 and 350 series AP/Bridges ?
2. I am planning on 1 Sector per AP/Bridge, What should I use to connect the 3+ AP/Bridges together to maximize # of users and Bandwidth ?
4. I wasted serveral days working with a Wireless Router vendor who ** forgot ** to tell me that his router was not 802.11b Compatible.
Soooo I want to be sure this time... are the 340 and 350 Series AP's compatible with 802.11b.. Will I need to rely on Cisco on both the CO and CPE site or will a Linksys AP work at the CPE side ?
5. Has anybody used Antennas from Hyperlink.com for a Wireless ISP Solution ? In combonation with the Cisco 340 or 350 AP's
6. Im am blowing about 250,000.00 on Cisco Aironet Hardware this week. can anybody suggest a good Reseller or another reliable source of Hardware ?
Sorry so many questions.
Thank you
Chris s. Raver
CEO Project Wireless
03-03-2002 04:36 PM
Yes, the 340s and 350s are 802.11b, HOWEVER, all vendors use proprietary methods for bridge links because the 802.11b spec maxs out at 1 mile.
We can get you the equipment (and we charge less than Hyperlink for a lot of the same equipment), however you still have some fundamental issues to tackle, like:
-The client device is either a client or a bridge, not an AP, not from any manufacturer.
Matthew Wheeler
03-06-2002 05:47 PM
If you contact your local Cisco rep, they can probably let you know of any suppliers/partners in the area.
