Community Member
Cisco Aironet radios and/or power remote management
Dear all,
I'm working on a wifi network composed by a Cisco 2500 Wireless Controller and several Cisco Aironet 2600.
My objective is implement a semplified control (not using native GUI from WLC) to manage (enable/disable) radios of each APs connected to WLC.
A primary example might be the use of SNMP protocol to comunicate with APs, but the AP's supported MIBs seem not mention any usefull commands to perform this operation.
Could someone provide feedbacks regarding this issue?
Thanks and reagrds
Tommaso
Everyone's tags (6)
1 REPLY
Hall of Fame Super Silver
Don't know how much you will
Don't know how much you will be able to configure using just snmp.  Typically you would use Prime Infrastructure to schedule or push templates to WLC(s).  Otherwise you would have to use CLI commands and script that.
-Scott
83
