Community Member
Cisco Antenna (AIR-AP1242AG) Question
Is the below Cisco Sector Antenna AIR-AP1242AG rated for outdoor installation/mounting or is it indoor mountable only?
Also does anyone know if it comes with U-bolts/clamps for mounting to a mast/pole?
Dimensions and Mounting Specifications
Azimuth Plane Radiation Pattern
Elevation Plane Radiation Pattern
Frequency Range
2.4-2.5 GHz
VSWR
1.5 or less
Gain
5.0 dBi
Polarization
Linear vertical
Azimuth 3dB Beamwidth
135 degrees
Elevations 3dB Beamwidth
54 degrees
Antenna Connector
RP-TNC
Cable Length
3 ft. (91 cm)
Dimensions
6 x 3 x 2 in (15.2 x 7.6 x 5 cm)
Mounting
Wall Mount
1 REPLY
Hall of Fame Super Red
Hi there,
The Antenna you have referenced is an AIR-ANT2450S-R the specs are shown below
AIR-ANT2450S-R Sector, 1 port Wall mount indoor/outdoor antenna with RP-TNC connector for use with any
2.4 GHz radio. Capable of covering large areas. The plenum rated cable is 36” long.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/product_data_sheet09186a008008883b.html
It is listed as a "Wall Mount" so it doesn't come with any u-bolts.
Cheers!
Rob
"Everything is broken" - Bob Dylan
1463
