07-16-2002 12:18 PM - edited 07-04-2021 11:18 PM
Hello all,
I have tried following the instructions provided on the TAC site to reset the AP to default settings, but this procedure doesn't seem to work. The AP has a firmware = 11.17 When I tried to enter the :resetall command specified in the support docs via the serial port, this doesn't do anything, and I get prompted for the username. I have also tried to use the pin reset, but this doesn't seem to solve it either. Could someone please advice on any other ways to get the AP reset? We need to deploy this AP, but need to have it reconfigured.
Thanks in advance
dp
07-19-2002 11:18 AM
The :resetall all command needs to be done within 2 minutes of reset/power up. This may make a difference with what you've tried?
07-23-2002 09:31 AM
Pl. make sure that you follow the procedure which is documented at
http://www.cisco.com/warp/public/102/wlan/pwrec-2.html#resetap
for versions 11.07 and later..
If stiil no luck , open a tac case at www.cisco.com/tac
08-10-2002 02:06 PM
I have an identical problem, version 11.21 on AP352E2R. Did you get a solution from TAC? I had set the security to disable read-only browsing without login, and must have typed the password wrongly, twice! When I try to do a :resetall I get prompted for username and password. Five other 352s work fine and behave as in the documentation, but they all have read-only browsing enabled.
Neil
