Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco AP1200 Management
I have Aironet 1200s that I am setting up with multiple vlans and security, I have been able to get all the vlans to work the way I want and the security to work. However I need a way to manage the AP remotely and I have not been able to get a management connection to the AP, I have tried configuring a subif, using the native vlan, nothing seems to work, here is my configuration and currenlty on the switch I a native vlan set, which is not VLAN 1.
version 12.3
ip subnet-zero
no aaa new-model
dot11 ssid Staff
vlan 92
authentication open
authentication key-management wpa
wpa-psk ascii 7 ****************
dot11 ssid Students
vlan 91
authentication open
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 92 mode ciphers tkip
ssid Staff
ssid Students
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
station-role root
rts threshold 2312
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.91
encapsulation dot1Q 91
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio0.92
encapsulation dot1Q 92
no ip route-cache
no cdp enable
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
bridge-group 1 spanning-disabled
hold-queue 160 in
interface FastEthernet0.91
no ip route-cache
bridge-group 2
interface FastEthernet0.92
no ip route-cache
bridge-group 3
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
1 REPLY
Purple
Re: Cisco AP1200 Management
You need to assign an ip address to the BVI interface along with a default gateway of the l3 routing device .
143
