05-11-2014 05:09 AM - edited 07-05-2021 12:48 AM
hi all,
I have cisco AP 1121 autonomous connected to my core switch, I can see it on the cdp neighbors with its IP and they are running but i cannot ping them or telnet them?
the port that connected on the AP is trunk.
what may be the problem ?? please advice
Solved! Go to Solution.
05-13-2014 05:01 AM
According to your configuration, they should. BVI1 is configured as your Management VLAN and this is tied to VLAN 1.
Bridge-Group 1 is always tied to BVI1.
05-11-2014 05:15 AM
Post the config of your 1121 and the interface config of the switch.
05-11-2014 08:19 AM
thanks alot for your reply :)
I will go to the customer and post these output.
05-12-2014 03:28 PM
hi Leo Laohoo
these are the interface configuration:
interface FastEthernet0/14
switchport trunk allowed vlan 1,133,144,1002-1005
switchport mode trunk
spanning-tree portfast
the configuration of AP:
Building configuration...
Current configuration : 2923 bytes
version 12.3
no service pad
service password-encryption
hostname Room-547
no logging console
enable secret 5 $1$8vkK$fKUJT.m.dsDa/yp/bErUu1
username Cisco password 7 13261E010803
ip subnet-zero
no aaa new-model
dot11 vlan-name management vlan 1
dot11 vlan-name wireless_data vlan 133
dot11 vlan-name wireless_voice vlan 144
dot11 ssid Guest_Data1
vlan 120
authentication open
dot11 ssid Guest_Data2
vlan 122
authentication open
dot11 ssid Holiday Inn
vlan 133
authentication open
guest-mode
dot11 ssid Voice
vlan 144
authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid Holiday Inn
ssid Voice
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
channel 2462
station-role root
world-mode dot11d country FR both
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.133
encapsulation dot1Q 133
no ip route-cache
bridge-group 133
bridge-group 133 block-unknown-source
no bridge-group 133 source-learning
no bridge-group 133 unicast-flooding
bridge-group 133 spanning-disabled
interface Dot11Radio0.144
encapsulation dot1Q 144
no ip route-cache
bridge-group 144
bridge-group 144 subscriber-loop-control
bridge-group 144 block-unknown-source
no bridge-group 144 source-learning
no bridge-group 144 unicast-flooding
bridge-group 144 spanning-disabled
no ip address
no ip route-cache
duplex auto
speed auto
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.133
no ip route-cache
bridge-group 133
interface FastEthernet0.144
no ip route-cache
bridge-group 144
interface BVI1
ip address x.x.x.x x.x.x.x.x
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
login local
transport input all
line vty 5 15
login
transport input all
end
appreciate your support
05-12-2014 04:58 PM
I presume your AP BVI1 and your VLAN 1 are in the same subnet?
05-13-2014 03:27 AM
are they must be in the same subnet ??
05-13-2014 05:01 AM
05-17-2014 07:31 PM
Thank you for taking the time to rate our posts.
