Cisco Autonomous AP not pingable from the core switch
hi all,
I have cisco AP 1121 autonomous connected to my core switch, I can see it on the cdp neighbors with its IP and they are running but i cannot ping them or telnet them?
the port that connected on the AP is trunk.
what may be the problem ?? please advice
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
According to your
According to your configuration, they should.  BVI1 is configured as your Management VLAN and this is tied to VLAN 1.
Bridge-Group 1 is always tied to BVI1.
Post the config of your 1121
Post the config of your 1121 and the interface config of the switch.
thanks alot for your reply :)
I will go to the customer and post these output.
hi Leo Laohoothese are the
hi Leo Laohoo
these are the interface configuration:
interface FastEthernet0/14
 switchport trunk allowed vlan 1,133,144,1002-1005
 switchport mode trunk
 spanning-tree portfast
the configuration of AP:
Building configuration...
Current configuration : 2923 bytes
version 12.3
no service pad
service password-encryption
hostname Room-547
no logging console
enable secret 5 $1$8vkK$fKUJT.m.dsDa/yp/bErUu1
username Cisco password 7 13261E010803
ip subnet-zero
no aaa new-model
dot11 vlan-name management vlan 1
dot11 vlan-name wireless_data vlan 133
dot11 vlan-name wireless_voice vlan 144
dot11 ssid Guest_Data1
   vlan 120
   authentication open
dot11 ssid Guest_Data2
   vlan 122
   authentication open
dot11 ssid Holiday Inn
   vlan 133
   authentication open
   guest-mode
dot11 ssid Voice
   vlan 144
   authentication open
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 ssid Holiday Inn
 ssid Voice
 speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
 channel 2462
 station-role root
 world-mode dot11d country FR both
interface Dot11Radio0.1
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
 bridge-group 1 spanning-disabled
interface Dot11Radio0.133
 encapsulation dot1Q 133
 no ip route-cache
 bridge-group 133
 bridge-group 133 block-unknown-source
 no bridge-group 133 source-learning
 no bridge-group 133 unicast-flooding
 bridge-group 133 spanning-disabled
interface Dot11Radio0.144
 encapsulation dot1Q 144
 no ip route-cache
 bridge-group 144
 bridge-group 144 subscriber-loop-control
 bridge-group 144 block-unknown-source
 no bridge-group 144 source-learning
 no bridge-group 144 unicast-flooding
 bridge-group 144 spanning-disabled
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 hold-queue 80 in
interface FastEthernet0.1
 no ip route-cache
 bridge-group 1
interface FastEthernet0.133
 no ip route-cache
 bridge-group 133
interface FastEthernet0.144
 no ip route-cache
 bridge-group 144
interface BVI1
 ip address x.x.x.x x.x.x.x.x
 no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging snmp-trap emergencies
logging snmp-trap alerts
logging snmp-trap critical
logging snmp-trap errors
logging snmp-trap warnings
bridge 1 route ip
line con 0
 transport preferred all
 transport output all
line vty 0 4
 login local
 transport input all
line vty 5 15
 login
 transport input all
end
appreciate your support
I presume your AP BVI1 and
I presume your AP BVI1 and your VLAN 1 are in the same subnet?
are they must be in the same
are they must be in the same subnet ??
According to your
Thank you for taking the time
Thank you for taking the time to rate our posts.  laugh
57
