11-04-2014 03:56 AM - edited 07-05-2021 01:52 AM
What command can I run in CLI, to get a mac address that is associated with a provided ip address?
Context: In order to access wifi, users have to go through a web authentication. Upon submiting their credentials, we are able to see their ip address. We want to query router api with cli or something, to find a mac address based on the ip.
Any pointers?
Solved! Go to Solution.
11-24-2014 01:59 AM
Yes this is a very basic way of getting it, In the past you could not even do this & Cisco added this feature only from 7.5.x code onward.
So you cannot do lot of filtering on this, hope Cisco will improve it further. So you need to live with those limitation at the moment :)
Rasika
11-05-2014 03:06 PM
"show ip arp" may be helps you.
Rasika
**** Pls rate all useful responses ***
11-19-2014 03:33 AM
A follow up question - do I run this against the Wireless Controller or the Access Point? I do not seem to be able to find command information for my hardware (3560-C switch, 2500 series WLC and 2700 AP)
11-24-2014 12:20 AM
11-24-2014 12:42 AM
Try to get "show client summary" output from your WLC at the time you get "show ip arp" output from your 3560 switch.
In that way we can compare whether your wireless client entry shown in WLC/Switch or not
Rasika
**** Pls rate all useful responses ****
11-24-2014 01:40 AM
I actually found a possibly better solution. Running "show arp switch" against the WLC, outputs a table (see attachment).
It's basically what I need, except I cannot find a way to filter the command by a mac address. Something along the lines of "show arp switch | <ip address to find>" would be perfect. Any ideas?
11-24-2014 01:46 AM
Try this command, you can include MAC address or IP address of your client as you want.
(WLC-01) >grep include '04:FE:7F:68:A4:54' 'show arp switch'
Rasika
11-24-2014 01:55 AM
11-24-2014 01:59 AM
Rasika
11-24-2014 12:41 AM
It is usually not possible for a person to get the MAC address of a computer from its IP address alone. These two addresses originate from different sources. Simply stated, a computer's own hardware configuration determines its MAC address while the configuration of the network it is connected to determines its IP address.
However, computers connected to the same TCP/IP local network can determine each other's MAC addresses. The technology called ARP - Address Resolution Protocol included with TCP/IP makes it possible. Using ARP, each computer maintains a list of both IP and MAC addresses for each device it has recently communicated with.
Most computers allow you to see the list of IP and MAC addresses that ARP has collected there. In Windows, Linux and other operating systems, the command line utility "arp" shows this information. Using "arp," you can in fact determine the MAC address of some computers from their IP address. ARP works only within the small group of computers on a local area network (LAN), though, not across the Internet. ARP is intended for use by system administrators and is not generally useful as a way to track down computers and people on the Internet.
