Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cisco PI alarms by group of ports
hi all,
I need to know how can i apply alarms on group of ports if these ports have a utilization of 0%
please advice
thanks in advance
Everyone's tags (1)
Hall of Fame Super Gold
Doesn't make sense.  Do you
Doesn't make sense.
Do you want to generate a report about ports that haven't been used since the last time the switch was rebooted?  Or XX amount of days/weeks?
Or do you want to constantly harassed by PI to tell you "port X/Y/Z" hasn't been used, period.
hi Leo Laohooوthanks for your
hi Leo Laohooو
thanks for your kindly reply
i need PI to tell me "port X/Y/Z" hasn't been used, period. by e-mail notification.
thanks in advance
I'm not sure if there are any
I'm not sure if there are any products in the market that will do something like what you are asking:  Regularly determine how many un-used ports and send email of the result.
The reason is common sense:  Your email will get clogged.
The best method I've seen, so far, is using SNMP to poll each port and determine how long the ports haven't been used and generate a report.  This method is initiated manually.
35
