Cisco Spectrum Expert
I have downloaded Cisco Spectrum Expert and installed on a dell notebook running windows8.
Then I started looking for a sensor card.
I hav gotten Cisco Spectrum Expert Wi-Fi (CardBus) - AIR-CSCO-SE-WIFI-C reference and I am concerned with 2 facts.
1. dell notebook does not have a compatible interface to attach this card;
2. it is a very expensive card.
Is there any other sensor card interface compatible with dell xps 12?
Thanks in advance.
Rosa
2 ACCEPTED SOLUTIONS
VIP Purple
You can use a Cisco AP in "SE
You can use a Cisco AP in "SE-Connect" - Spectrum Expert mode as the sensor. In this way you do not require any compatible cards
here how you do it
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010001100.pdf
Rasika
**** Pls rate all useful responses ****
Hall of Fame Super Gold
You may need to use a PCMCIA
You may need to use a PCMCIA-to-USB card.
VIP Purple
here how you do it
Rasika
Thanks a lot.I would be great
Thanks a lot.
I would be great if it is possible to use AP as sensor.
It is a less expensive.
Rosa
I wanted to use a 3702i autonomous AP in spectrum mode. But it does not show any devices and all it shows is "waiting for devices". I read somewhere that only the spectrum exert card shows devices. Is this true?
Abebe
Thanks Leo.I will try  to use
Thanks Leo.
I will try  to use AP as sensor.
It is a less expensive option.
Rosa
Rosa, Talk to your SE.  If
Rosa,
Talk to your SE.  If the PCMCIA card is un-used, you may be able to return it or get a credit.
Thanks for taking the time to rate our posts.  :)
I have configured AIR
I have configured AIR-CAP3502I-A-K9  AP Mode as SE-CONNECT for using Cisco Spectrum Expert 4.1.
Cisco Spectrum Expert shows Spectrum AQ, Spectrum (2) graphs.
It can not show devices. In Active Devices:
... Waiting for Devices ...
Channel Summry sows incomplete as no APs are found.
Any idea?
It is running fine.In fact
It is running fine.
In fact there is few interference where ap is depoyed.
I have already seen a bluetooth piconet device.
557
