04-10-2012 08:50 PM - edited 07-03-2021 09:58 PM
Just wondering of this model of WAP - AIR-CAP3502I-X-K9—802.11a/g/ is working standalone with out a controller , or is it only controller based ?
Thanks.
04-10-2012 08:55 PM
You need a controller running 7.0.X firmware.
04-10-2012 08:56 PM
Ok thanks. Whats the best model these days with no external anteans that supports 802.11a/g/n ? is it 1140 ?
04-10-2012 08:59 PM
External antennas? 1260 if you want autonomous.
BTW, AIR-CAP3502I-X-K9 is an INTERNAL antenna model of this WAP
04-10-2012 09:00 PM
Depends on your need.
1040 is a 2x2 soho model that comes with 2 models 802.11g/n and 802.11a/g/n
1140 is a 2x3 enterprise model that comes with 2 models 802.11g/n and 802.11a/g/n
1260 is a 2x3 enterprise model
3500 is a 2x3 enterprise model that comes with 2 models 802.11g/n and 802.11a/g/n also clean air
3600 is a 3x3 enterprise model that comes with 2 models 802.11g/n and 802.11a/g/n
All depends on your need and design requirements.
04-10-2012 09:28 PM
Thanks . Yeah looking at a model that does a/g/n with external antenas , autonomous.
04-10-2012 09:33 PM
You are looking at the 1260 model then. Keep in mind you can not go more then a 6 dBi gain antenna on them,
04-10-2012 09:37 PM
Thanks. Cheers for the tips.
What's your opinion on 1140 series ? Are they end of life ?
04-10-2012 10:16 PM
The 1140 are still in the market.
04-10-2012 10:18 PM
1140 is more of indoor ap. The 1260 is a more rugged ap. Both are great aps. I have both deployed in my enviroment.
04-10-2012 08:56 PM
You need a controller, "officially". However, you could load a cisco 1260 autonomous code on it and it will work. BUT, its officially not supported by Cisco.
04-10-2012 08:58 PM
Thanks Geoff. I guess that we won't be eligible to download that code for this officialy then .
