Cisco Wireless 3GHz support.
I have a client who is regestired to use the 3GHz frequency. Does any one know if the Cisco range can be altered to support this frequency.
Re: Cisco Wireless 3GHz support.
No. The Aironet range (350's & 1200's) only support the unlicensed 802.11a and 802.11b standards.
Cisco does have some carrier wireless products, but I assume your question is regarding the consumer/commercial access points. Altering the radio frequency would be: (a) really hard, probably impossible, given that most of it's in the chipset; (b) probably illegal, and break FCC/Austel/whatever regulations.
thank you for the feed back. what wireless technology could an isp use if they have the 3GHz frequency registered for their own use.
Cisco uses the 3.4 - 3.6 GHz frequencies for ETSI regulation with what is called the Cisco WT-2750 Multipoint Broadband Wireless according to the site http://www.cisco.com/warp/public/102/wwan/p2mp-faq.html#3.
U-NII regulation is in the 5.725 - 5.825 GHz frequency range
Don't know much about it except that the feature is removed from newer IOS
Thanks for your help.
This product is EOP heading for EOL check this out : http://www.cisco.com/warp/public/cc/general/bulletin/witc/1579_pp.htm
168
