Community Member
Cisco WISM2 Unknow log
Hi all
Sometimes I cannot login WISM via WEB. There are the logs , I donot know  what is the mean of it.
--------------------------------------------------------------------------log--------------------log----------------log--------------------------------------------------------------------------
*emWeb: Mar 24 08:59:04.796: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 08:43:04.711: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 08:28:04.625: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 24 08:28:04.625: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 08:12:04.489: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 07:56:04.407: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 07:40:04.322: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 07:24:04.245: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 07:09:04.168: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 24 07:09:04.168: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 06:53:04.070: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 06:37:03.978: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 06:21:03.890: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 06:05:03.822: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 05:50:03.721: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 24 05:50:03.721: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 05:34:03.642: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 05:18:03.546: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 05:02:03.474: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 04:46:03.382: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
*emWeb: Mar 24 04:31:03.280: #CLI-3-LOGIN_FAILED: cliutil.c:653 Login failed. User:nouser, Service type:-8. excessive failed login attempts.
*emWeb: Mar 24 04:31:03.280: #CLI-3-LOGIN_FAILED: cliutil.c:576 Login failed. User:nouser, Service type:-8. Username/Password length must be between 3 and 24 characters.
notice:   I am sure that no one try to login the wism via web or ssh so many times!
VIP Purple
Hi,1. do you have radius
1. do you have radius setup for managment?  If you have radius setup, please check that  you don't have the managmeent check box enabled unless you are using TACACS or RADIUS for management users.
2. Check the username and password length...it must be between 3-24 char.
3. Still failing then please contatc TAC, they may help you.
Dont forget to rate helpful posts
Community Member
Thank U for your answer1. I
1. I have radius setup but not use for management.
2. I am sure the password length betwen 3-24 char.
VIP Purple
HI Chen,Then it will good to
HI Chen,
Then it will good to raise a TAC case.
May be its a bug ...TAC guys can tell you in detail.
Community Member
thank u very much indeed.
42
