Cisco WLC 5760 Load Balancing and Licensing
I am trying to figure out following as we are close to upgrade the current WLC 5508 pair.
1. Can Cisco WLC 5760 do load balancing? For example, I bought two 5760 to manage 700 APs. Can I configure to have 400 APs registered with 5760#1 and 300 APs registered with 5760#2?
2. With WLC 5508, I have to buy 500-AP license in order to configure HA to manage up to 250 APs. Will the WLC5760 require the same licensing setup? I am looking for two WLC5760 with 700 APs. Does this mean, I need to buy 700-AP license for each WLC?
3. Do I need the HA/Redundancy license?
/S
3 ACCEPTED SOLUTIONS
Re: Cisco WLC 5760 Load Balancing and Licensing
Licensing is going to depend on what you want to have.
If you want to have full redundancy with load balancing you would need to purchase 700 AP licese for each WLC.
   this will allow either WLC to hold all the AP should one go down, and allow you to put some AP on WLC A and some on WLC B.
You could do HA as well, and you would only need one 700 AP license, but you get no load balancing of the AP, they willl all reside on the WLC that is currently 'hot'.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
VIP Purple
If you need to to load balance the:
2 X AIR-CT5760-1K-K9
If you need HA then:
1 X AIR-CT5760-1K-K9
1 X AIR-CT5760-HA-K9
Here is the guide of HA AP SSO deployment:
http://www.cisco.com/en/US/docs/wireless/controller/technotes/5700/software/release/ios_xe_33/5760_HA_DG_iosXE33.pdf
Hope it helps.
Dont forget to rate helpful posts
VIP Purple
If you are using 5760 as a central controller  without  3850/3650 to terminate CAPWAP, then pretty much 5760 is doing the function of 5508 & HA would be active/standby (not active/active)
If you are using 5760 as MC & 3850/3650 as MA, then all your CAPWAP terminates on your MAs. Even MC fails it does not matter as no CAPWAP terminate on 5760 itself.(there is a impact for certain things like inter-SPG roaming, RRM,etc)
Here is the reference document I have on this CA architecture which may help you to understand these concepts (it is dated 2013 June & may not be upto date with latest code enhancements)
CONVERGED ACCESS – WIRED / WIRELESS SYSTEM ARCHITECTURE, DESIGN, AND OPERATION
Rasika
**** Pls rate all useful responses ****
VIP Purple
1.I think Yes it is supported:
http://www.cisco.com/en/US/docs/wireless/technology/5760_deploy/Supported_Features.html
But i will recommand to buy 5508 or 8500 WLC
2. You cab buy one 5508 WLC with fUll AP licencee and 2nd WLC with HA SKU(Empty Licence).
5508 maximum AP support 500 AP;
3. With the answer of 2nd ,You can configure HA. You need to have above then 7.3 image on wlc.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
https://supportforums.cisco.com/docs/DOC-26827
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps10315/qa_c67-714540_ps2706_Products_Q_and_A_Item.html
Thanks.
I thought the scenario with that link only applies to one WLC. I would need AP load balancing between two WLC automatically.
Why 8500 or 5500 over 5760?
VIP Purple
HI,
I am not much aware 5760 WLC.:
Just for info:(Cisco recommanded that......
Do not enable aggressive load balancing unless the network has a high density of access points available in the area, and never if there is voice over wireless. If you enable this feature with access points spaced too far away from each other, it might confuse the roaming algorithm of some clients and induce coverage holes in some cases.
You can use one of them:(8500 or 5760)
http://www.cisco.com/en/US/docs/wireless/technology/5760_deploy/Supported_Features.html#wp1067388
I wrote 8500 because may be in future your AP count will increase more then 1000  . And 5760 supports max 1000 AP and 8500 supports upto 6000 AP.
Although u can check this link decide which is suitable for your enterprise.
Correct me if I am wrong, I thought the Agreesive Load Balancing is for wireless clients...we do not run voice over wireless...
Again, the link you provided is for single WLC to provide load balancing...
VIP Purple
Yes ALB is for Wireless Clients.
I think AP load balancing must be supported by 5760 WLC but not 100% sure
I dont have much experience with 5760 WLC(This is pretty new), so I can tell you exactly about this point
May be other experts can,,,,,
But with other WLCs , you can use:
http://www.cisco.com/en/US/tech/tk722/tk721/technologies_tech_note09186a00807a85b8.shtml
Yes, the 5760 will allow you to load balance the AP.  This is based on the Primary/Secondary WLC you configure on the AP.
HTH,
Steve
I guess this will need to be done manually per AP, right? No automatic AP load balancing?
VIP Purple
Thanks anyway.
So anyone knows about the licensing with WLC5760? What licenses do I need for a 700-AP with load balancing/redudant WLC5760 pair?
I am proposing following two SKUs:
1xAIR-CT5760-1K-K9 and 1xAIR-CT5760-HA-K9
VIP Purple
Cisco 5760 WLC and the Cisco Catalyst 3850 will support RTU-based access point count licensing.
http://www.cisco.com/en/US/prod/collateral/wireless/ps6302/ps8322/ps11635/qa_c67-713536.html
regards
HTH,
Steve
So I would need 2xAIR-CT5760-1K-K9 to do the load balancing and HA. If that is the case, do I still need "1xAIR-CT5760-HA-K9"?
If I did not need the load balancing, the "1xAIR-CT5760-1K-K9 and 1xAIR-CT5760-HA-K9" setup should be enough, right?
VIP Purple
Hope it helps.
Thanks. That does help...
To help my slow brian more clear: 2 X AIR-CT5760-1K-K9 should give me both Load balancing and HA for 700-AP, right? I do not need to buy AIR-CT5760-HA-K9...
VIP Purple
Yes, 2 X AIR-CT5760-1K-K9 load balance
If you need to configure HA then you need
1 X normal 1000 AP licence
1 X HA SKU (Means zero Licence)
VIP Purple
The same I link posted above in
Rregards
Dont forget to arte helpful post and mark this question as answered, it may help others
VIP Purple
HI,
Information:
5760 does not support HA AP SSO with 3.2.2 version.
You can do the traditional two controller setup. Where you can have a 1:1 redundancy or split the APs across the two controllers.
With IOS XE 3.3.0SE AP SSO is supported when using the controller stack cable. So the 5760 and 5760-HA is in a stack and HA is enabled by default when stacked.
regards
VIP Purple
Yes, I am more towards 5760/3850 (Converege Access)  compare to 5508 (Unified Access) . This is based on bandwidth demand due to 802.11ac & having requirement of consistent QoS & Security policy for wired & wireless in our campus environment.
Feature wise you cannot compare 5760 to 5508 as CA still behind & trying to catch up. So do not try to match 1:1 what you are able to do with 5508 & what 5760 can do.
I am  doing testing with 5760/3850 at the moment & it will take time to absorb this new CA concepts & design (not many good documentation available to public)
for me, 5760 is the platform to go with in the given scenario (8500 is more for service providers & 5508 is what he currently got). But you need to understand the paradigm shift from CUWN to CA when deploying that product.
Rasika
****Pls rate all useful responses ****
I actually was reading your blog post regarding the 5760/3850...
do u have any link that you can share about the CUWN vs CA?
VIP Purple
I will do  a  post on that   (in coming weeks)
Rasika
VIP Purple
Thanks rasika
I am totally dedicated to you...following ur footsteps---> CCIEW
VIP Purple
Hi Sandeep,
Hope you will get it soon... You are on right track
KIT
Rasika
Hey, Rasika
Do you know if WLC 5760 pair with stackwise cables can do Active/Active HA/LB?
VIP Purple
Rasika
Cool, I now have something to read after dinner tonight...
Part of the reason I kept asking about fully redundancy with Load balancing, aruba controllers provide the active-active redundancy with load balancing without charging extra... Just wonder why cisco can not do Active-Active...
VIP Purple
HI,
Can u mark this question as answered, it may help others.
Please rate helpful posts accordingly.
VIP Purple
I have posted few more references for CA under below thread
https://supportforums.cisco.com/thread/2249117
Feel free to go through it if you are going for 5760 & this CA architecture sometime in future.
Also pls rate our responses accordingly if that is useful to you.
Rasika
**** Pls rate all useful resposnes ****
695
