Cisco WLC Virtual
furio
hi guys,
after a vmotion the serial number has changed !!
Is this normal?
6 Replies 6
Saurav Lodh
Level 7
Level 7
For your Information
https://tools.cisco.com/bugsearch/bug/CSCun11124
Sandeep Choudhary
Hi Furio,
No its not normal, its a bug: CSCun11124
Which version are you running on WLC ?
Use this version: 7.6.120.1
Dont forget to rate helpful posts
Hi Sandeep,
I'm having this same issue which is causing my APs not to join to the controller after moving them over. Is this still a beta copy? 7.6.120.1, i'm running 7.6.120.0 at the moment.
Abhishek Abhishek
Please upgrade to the version 7.6 or higher.
gohussai
Level 4
Level 4
Yes its a bug but i haven't tried this on Hyper-v ,you can test the same after up gradation of firmware and see if this happen on Hyper-v live migration also .
Abhishek Abhishek
vWLC serial number changes when using DRS or Vmotion
CSCun11124
Symptom:
Conditions:
when using DRS or vMotion to maintain high availability on vmare the UUID changes and invalidates the AP licenses.
Workaround:
setup DRS rules or do not use vmotion to keep vWLC on single host.
