02-13-2014 01:34 AM - edited 07-05-2021 12:11 AM
Is it possible to use XenMobile MDM to do wireless certificate base authentication for Cisco WLC clients without the use of ISE?
Solved! Go to Solution.
02-13-2014 04:48 AM
Maurice,
If you have AD and your a Microsoft shop, here are some examples of using Microsoft NPS;
https://supportforums.cisco.com/docs/DOC-32752
http://networklessons.com/wireless/peap-and-eap-tls-on-server-2008-and-cisco-wlc/
02-13-2014 01:42 AM
Certificate based authentication, 802.1x, requires a radius server. MDM will not work as a radius server unless XenMobile has done something new. You don't need ISE, but you can use any radius server from Microsoft, Cisco or even FreeRadius.
02-13-2014 02:25 AM
Thanks, do you know where I can find a example or information on how this is setup?
02-13-2014 04:48 AM
Maurice,
02-13-2014 05:36 AM
Great information thanks
02-13-2014 05:40 AM
No problem
