Ciso 1231 Date and Time
Hi All
This is only the 2nd tim eI have asked for advice, the first time you all came up trumps and sorted my problem.
The issuse this time round it that I have a Cisco 1231 AP, when I view the logs via the web interface the date and time are incorrect and I can't find the option to change/set these anywhere.
Thanks in advance
Derek
1 REPLY
Silver
Re: Ciso 1231 Date and Time
Hi Derek,
in the Webinterface navigate to "Services -> SNTP". There you will find a section "Time Settings".
Best regards,
Frank
131
