Which is the problem when the CLI is like this? and what do I have to make?
ap:
ap: ?
? -- Present list of available commands
arp -- Show arp table or arp-resolve an address
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
clear_ether -- clear ethernet port statistics
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
dump_save_regs -- dump saved regs in OCM
etest -- test emac driver code
ether_init -- initialize ethernet port
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
init_pci -- initialize pci bridge
led_test -- cycle led patterns
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
-- MORE --
