06-12-2008 05:39 AM - edited 07-03-2021 04:01 PM
We have begun experiencing client disconnects on one of our WLAN sites. The site has several point-to-point mesh links, these have also started to fail (PAP loses connection with RAP). In the WLC trap log we see a lot of the following messages:
2 Thu Jun 12 12:59:20 2008 Client Deauthenticated: MACAddress:00:20:a6:60:e7:65 Base Radio MAC:00:0b:85:7f:7b:70 Slot: 1 Reason:Unspecified ReasonCode: 1
3 Thu Jun 12 12:58:59 2008 Client Deauthenticated: MACAddress:00:20:a6:60:e7:65 Base Radio MAC:00:0b:85:7f:7b:70 Slot: 1 Reason:Unspecified ReasonCode: 1
4 Thu Jun 12 12:58:38 2008 Client Deauthenticated: MACAddress:00:20:a6:60:e7:65 Base Radio MAC:00:0b:85:7f:7b:70 Slot: 1 Reason:Unspecified ReasonCode: 1
5 Thu Jun 12 12:58:16 2008 Client Deauthenticated: MACAddress:00:20:a6:60:e7:65 Base Radio MAC:00:0b:85:7f:7b:70 Slot: 1 Reason:Unspecified ReasonCode: 1
6 Thu Jun 12 12:57:55 2008 Client Deauthenticated: MACAddress:00:20:a6:60:e7:65 Base Radio MAC:00:0b:85:7f:7b:70 Slot: 1 Reason:Unspecified ReasonCode: 1
I've tried finding information on this, and the little information I've found points to low coverage. We will perform a new radio survey, but could this be caused by other things? We are currently running version 4.0.179.11 on a Cisco WLC 4402.
We are also seing the following errors, wich leads me to believe that this is a coverage problem.
0 Thu Jun 12 13:33:35 2008 RF Manager updated Channel for Base Radio MAC: 00:0b:85:7f:7a:f0 and slotNo: 0. New Channel is: 40
1 Thu Jun 12 13:33:35 2008 Radar signals have been detected on channel 52 by 802.11a radio with MAC: 00:0b:85:7f:7a:f0 and slot 0
2 Thu Jun 12 13:33:33 2008 RF Manager updated Channel for Base Radio MAC: 00:0b:85:7f:7b:30 and slotNo: 0. New Channel is: 56
3 Thu Jun 12 13:33:33 2008 Radar signals have been detected on channel 52 by 802.11a radio with MAC: 00:0b:85:7f:7b:30 and slot 0
4 Thu Jun 12 13:29:23 2008 Coverage Hole Detected for AP Nyn-Ap1 Bar 7f:7a:f0 whose Base Radio MAC is 00:0b:85:7f:7a:f0. Number of Failing Clients 3
5 Thu Jun 12 13:28:26 2008 Coverage hole cleared for Base Radio MAC: 00:0b:85:7f:7b:30 and slotNo: 1
6 Thu Jun 12 13:25:26 2008 Coverage Hole Detected for AP Nyn-Ap6 Moterom 7f:7b:30 whose Base Radio MAC is 00:0b:85:7f:7b:30. Number of Failing Clients 1
But what is strange is that the solution will work fine for a long time, then suddenly generate these severe problems. As far as we can determine there has been no changes on the site (no new walls, etc).
Solved! Go to Solution.
01-30-2013 08:42 AM
Hey Justin,
I too am facing the same issue and see the decrypt errors.
Wed Jan 30
18:11:28 2013
Coverage hole pre alarm for client[1] a0:f4:50:b7:35:16 on 802.11b/g interface of AP 00:3a:98:63:0e:c0 17 27 6 2 2 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Wed Jan 30
18:10:21 2013
Coverage hole pre alarm for client[1] a0:f4:50:b7:35:16 on 802.11b/g interface of AP 00:3a:98:63:0e:c0 10 26 12 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Wed Jan 30
18:08:27 2013
Coverage hole pre alarm for client[1] 30:39:26:87:58:c1 on 802.11b/g interface of AP 00:3a:99:bf:1d:a0 45 18 6 7 3 6 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Wed Jan 30
18:05:14 2013
Client Excluded: MACAddress:b0:c4:e7:1d:e6:1a Base Radio MAC :00:3a:98:86:6d:c0 Slot: 0 User Name: Address: unknown Reason:802.11 Association failed repeatedly. ReasonCode: 2
Wed Jan 30
18:01:04 2013
Client Excluded: MACAddress:b0:c4:e7:1d:e6:1a Base Radio MAC :00:3a:98:78:cd:40 Slot: 0 User Name: Address: unknown Reason:802.1x Authentication failed 3 times. ReasonCode: 4
Wed Jan 30
17:55:07 2013
6
Wed Jan 30
17:53:27 2013
Client Excluded: MACAddress:b0:c4:e7:1d:e6:1a Base Radio MAC :00:3a:98:78:cd:40 Slot: 0 User Name: Address: unknown Reason:802.11 Association failed repeatedly. ReasonCode: 2
7
Wed Jan 30
17:44:13 2013
Coverage hole pre alarm for client[1] 90:21:55:72:8d:73 on 802.11b/g interface of AP 00:3a:98:86:2f:80 11 5 6 12 12 22 13 8 3 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
8
Wed Jan 30
17:39:11 2013
Client Excluded: MACAddress:50:01:bb:58:39:85 Base Radio MAC :00:3a:98:63:0e:c0 Slot: 0 User Name: Address: unknown Reason:802.11 Association failed repeatedly. ReasonCode: 2
9
Wed Jan 30
17:23:19 2013
Client Excluded: MACAddress:50:01:bb:58:39:85 Base Radio MAC :00:3a:98:78:cd:40 Slot: 0 User Name: Address: unknown Reason:802.11 Association failed repeatedly. ReasonCode: 2
Wed Jan 30
17:21:21 2013
Decrypt errors occurred for client a0:88:b4:34:b2:0c using WPA2 key on 802.11a interface of AP 00:3a:98:11
Wed Jan 30
17:11:59 2013
Decrypt errors occurred for client 90:c1:15:e8:e2:89 using WPA2 key on 802.11b/g interface of AP 00:
Please help if a hint is available.
06-13-2008 04:10 AM
Well as you can see on the log, you are interfereing with some radar around your area. Here is a link regarding that and might be the cause of your other log:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t11/ht_DFS.html
10-19-2011 12:32 AM
we have the same problem, and Cisco is unable to come up with an answer. The problem causes the clients to disconnect, and they have to reconnect manually.
0 | Wed Oct 19 09:26:11 2011 | Decrypt errors occurred for client 00:24:d6:8c:9f:1a using WPA key on 802.11a interface of AP 00:1e:4a:bf:8a:40 |
1 | Wed Oct 19 09:25:30 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
2 | Wed Oct 19 09:23:29 2011 | Client Deauthenticated: MACAddress:58:17:0c:4b:e3:80 Base Radio MAC:00:1e:4a:bf:b2:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.177 Reason:Unspecified ReasonCode: 1 |
3 | Wed Oct 19 09:22:27 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
4 | Wed Oct 19 09:22:26 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
5 | Wed Oct 19 09:22:03 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:1e:4a:bf:b2:90 |
6 | Wed Oct 19 09:20:29 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
7 | Wed Oct 19 09:20:11 2011 | Decrypt errors occurred for client 00:24:d6:8c:9f:1a using WPA key on 802.11a interface of AP 00:1e:4a:bf:8a:40 |
8 | Wed Oct 19 09:20:05 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
9 | Wed Oct 19 09:19:59 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
10 | Wed Oct 19 09:19:54 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
11 | Wed Oct 19 09:19:53 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
12 | Wed Oct 19 09:19:39 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:5c:ea:40 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
13 | Wed Oct 19 09:18:08 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
14 | Wed Oct 19 09:18:04 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:unknown IP Addr: unknown |
15 | Wed Oct 19 09:17:20 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
16 | Wed Oct 19 09:17:02 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
17 | Wed Oct 19 09:17:01 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
18 | Wed Oct 19 09:15:27 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
19 | Wed Oct 19 09:14:33 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
20 | Wed Oct 19 09:11:51 2011 | Client Deauthenticated: MACAddress:d8:9e:3f:1f:ad:3e Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.183 Reason:Unspecified ReasonCode: 1 |
21 | Wed Oct 19 09:11:37 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
22 | Wed Oct 19 09:11:36 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
23 | Wed Oct 19 09:10:26 2011 | Client Association: Client MAC:c4:17:fe:03:be:a6 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.181 |
24 | Wed Oct 19 09:10:26 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
25 | Wed Oct 19 09:06:37 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
26 | Wed Oct 19 09:06:31 2011 | Client Association: Client MAC:d8:9e:3f:1f:ad:3e Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
27 | Wed Oct 19 09:06:12 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
28 | Wed Oct 19 09:06:11 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
29 | Wed Oct 19 09:06:01 2011 | User gjest logged in. Client MAC:c4:17:fe:03:be:a6, Client IP:192.168.66.181, AP MAC:00:3a:98:65:f0:b0, AP Name:Foaje |
30 | Wed Oct 19 09:05:24 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
31 | Wed Oct 19 09:05:03 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
32 | Wed Oct 19 09:04:23 2011 | Client Association: Client MAC:c4:17:fe:03:be:a6 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:unknown IP Addr: 192.168.66.181 |
33 | Wed Oct 19 09:03:51 2011 | Client Association: Client MAC:c4:17:fe:03:be:a6 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:unknown IP Addr: unknown |
34 | Wed Oct 19 09:01:35 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
35 | Wed Oct 19 09:01:16 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
36 | Wed Oct 19 09:00:59 2011 | Client Association: Client MAC:00:24:d6:8c:9f:1a Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 1 User Name:host/NUSBLAP8.dsb.no IP Addr: 10.66.16.100 |
37 | Wed Oct 19 09:00:47 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
38 | Wed Oct 19 09:00:46 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
39 | Wed Oct 19 09:00:23 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
40 | Wed Oct 19 08:59:43 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
41 | Wed Oct 19 08:58:55 2011 | User gjest logged in. Client MAC:f8:1e:df:e7:ab:a5, Client IP:192.168.66.180, AP MAC:00:1e:4a:bf:8a:40, AP Name:U1_vegg |
42 | Wed Oct 19 08:58:20 2011 | Client Association: Client MAC:f8:1e:df:e7:ab:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 1 User Name:unknown IP Addr: unknown |
43 | Wed Oct 19 08:57:50 2011 | User gjest logged in. Client MAC:e0:f8:47:3f:8e:f4, Client IP:192.168.66.169, AP MAC:00:1e:4a:bf:8a:40, AP Name:U1_vegg |
44 | Wed Oct 19 08:57:39 2011 | AAA Authentication Failure for UserName:gjest User Type: WLAN USER |
45 | Wed Oct 19 08:57:22 2011 | Client Association: Client MAC:e0:f8:47:3f:8e:f4 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 1 User Name:unknown IP Addr: unknown |
46 | Wed Oct 19 08:55:22 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
47 | Wed Oct 19 08:55:21 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
48 | Wed Oct 19 08:55:21 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
49 | Wed Oct 19 08:54:11 2011 | Decrypt errors occurred for client 00:24:d6:8c:9f:1a using WPA key on 802.11a interface of AP 00:1e:4a:bf:8a:40 |
50 | Wed Oct 19 08:50:20 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
51 | Wed Oct 19 08:50:13 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
52 | Wed Oct 19 08:49:57 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
53 | Wed Oct 19 08:49:56 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
54 | Wed Oct 19 08:48:13 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
55 | Wed Oct 19 08:45:19 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
56 | Wed Oct 19 08:44:53 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
57 | Wed Oct 19 08:44:32 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
58 | Wed Oct 19 08:44:31 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
59 | Wed Oct 19 08:43:24 2011 | Client Deauthenticated: MACAddress:d8:9e:3f:1f:ad:3e Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.183 Reason:Unspecified ReasonCode: 1 |
60 | Wed Oct 19 08:43:10 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
61 | Wed Oct 19 08:40:18 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
62 | Wed Oct 19 08:39:07 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
63 | Wed Oct 19 08:39:06 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
64 | Wed Oct 19 08:38:04 2011 | Client Association: Client MAC:d8:9e:3f:1f:ad:3e Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
65 | Wed Oct 19 08:37:50 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
66 | Wed Oct 19 08:36:24 2011 | Client Association: Client MAC:d0:c1:b1:03:12:c3 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.175 |
67 | Wed Oct 19 08:35:20 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:3a:98:65:f0:b0 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
68 | Wed Oct 19 08:35:16 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
69 | Wed Oct 19 08:34:21 2011 | Client Deauthenticated: MACAddress:d8:9e:3f:1f:ad:3e Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.183 Reason:Unspecified ReasonCode: 1 |
70 | Wed Oct 19 08:34:17 2011 | Client Association: Client MAC:d0:c1:b1:03:12:c3 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.175 |
71 | Wed Oct 19 08:34:12 2011 | Decrypt errors occurred for client 00:24:d6:8c:9f:1a using WPA key on 802.11a interface of AP 00:1e:4a:bf:8a:40 |
72 | Wed Oct 19 08:34:08 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:1e:4a:bf:b2:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
73 | Wed Oct 19 08:33:45 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
74 | Wed Oct 19 08:33:45 2011 | Client Deauthenticated: MACAddress:00:1d:d9:3d:ba:df Base Radio MAC:00:3a:98:66:50:60 Slot: 0 User Name: unknown Ip Address: 192.168.66.121 Reason:Unspecified ReasonCode: 1 |
75 | Wed Oct 19 08:32:25 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
76 | Wed Oct 19 08:31:16 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
77 | Wed Oct 19 08:30:59 2011 | Client Association: Client MAC:00:24:d6:8c:9f:1a Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 1 User Name:host/NUSBLAP8.dsb.no IP Addr: unknown |
78 | Wed Oct 19 08:30:15 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
79 | Wed Oct 19 08:30:01 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
80 | Wed Oct 19 08:30:00 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:unknown IP Addr: unknown |
81 | Wed Oct 19 08:29:31 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.182 |
82 | Wed Oct 19 08:28:59 2011 | Client Association: Client MAC:d8:9e:3f:1f:ad:3e Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: unknown |
83 | Wed Oct 19 08:28:30 2011 | Client Association: Client MAC:e0:f8:47:c7:07:95 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
84 | Wed Oct 19 08:28:25 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:3a:98:66:50:60 Slot: 0 User Name:unknown IP Addr: 192.168.66.121 |
85 | Wed Oct 19 08:26:55 2011 | User gjest logged Out. Client MAC:f8:1e:df:e7:ab:a5, Client IP:192.168.66.180, AP MAC:00:3a:98:65:f0:b0, AP Name:Foaje |
86 | Wed Oct 19 08:26:55 2011 | Client Deauthenticated: MACAddress:f8:1e:df:e7:ab:a5 Base Radio MAC:00:3a:98:65:f0:b0 Slot: 0 User Name: gjest Ip Address: 192.168.66.180 Reason:Unspecified ReasonCode: 1 |
87 | Wed Oct 19 08:26:52 2011 | Client Association: Client MAC:00:1d:d9:3d:ba:df Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
88 | Wed Oct 19 08:26:21 2011 | Client Association: Client MAC:00:1d:e0:50:e5:4f Base Radio MAC :00:1e:4a:bf:d9:90 Slot: 0 User Name:gjest IP Addr: 192.168.66.179 |
89 | Wed Oct 19 08:26:13 2011 | User gjest logged Out. Client MAC:c4:17:fe:03:be:a6, Client IP:192.168.66.181, AP MAC:00:3a:98:66:4b:f0, AP Name:Forlengning |
90 | Wed Oct 19 08:26:13 2011 | Client Deauthenticated: MACAddress:c4:17:fe:03:be:a6 Base Radio MAC:00:3a:98:66:4b:f0 Slot: 0 User Name: gjest Ip Address: 192.168.66.181 Reason:Unspecified ReasonCode: 1 |
91 | Wed Oct 19 08:25:08 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:1e:4a:bf:d9:70 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
92 | Wed Oct 19 08:21:36 2011 | Rogue AP : 00:22:07:0c:99:02 removed from Base Radio MAC : 00:3a:98:66:50:60 Interface no:0(802.11b/g) |
93 | Wed Oct 19 08:20:45 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
94 | Wed Oct 19 08:19:48 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:1e:4a:bf:d9:70 Slot: 0 User Name:unknown IP Addr: 192.168.66.148 |
95 | Wed Oct 19 08:18:18 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:1e:4a:bf:8a:40 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
96 | Wed Oct 19 08:14:38 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:1e:4a:bf:d9:70 Slot: 0 User Name:unknown IP Addr: unknown |
97 | Wed Oct 19 08:07:40 2011 | Client Deauthenticated: MACAddress:98:03:d8:9e:a2:83 Base Radio MAC:00:3a:98:5c:ea:40 Slot: 0 User Name: unknown Ip Address: 192.168.66.148 Reason:Unspecified ReasonCode: 1 |
98 | Wed Oct 19 08:07:33 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
99 | Wed Oct 19 08:06:57 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:66:4b:f0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
100 | Wed Oct 19 08:03:24 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
101 | Wed Oct 19 08:02:18 2011 | Client Association: Client MAC:98:03:d8:9e:a2:83 Base Radio MAC :00:3a:98:5c:ea:40 Slot: 0 User Name:unknown IP Addr: unknown |
102 | Wed Oct 19 08:01:36 2011 | Rogue AP : 00:22:07:0c:99:02 detected on Base Radio MAC : 00:3a:98:66:50:60 Interface no:0(802.11b/g) with RSSI: -96 and SNR: -5 and Classification: unclassified |
103 | Wed Oct 19 08:01:16 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
104 | Wed Oct 19 07:54:02 2011 | Client Deauthenticated: MACAddress:58:17:0c:4b:e3:80 Base Radio MAC:00:3a:98:4d:3e:d0 Slot: 0 User Name: unknown Ip Address: 192.168.66.177 Reason:Unspecified ReasonCode: 1 |
105 | Wed Oct 19 07:48:42 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:unknown IP Addr: 192.168.66.177 |
106 | Wed Oct 19 07:43:22 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:1e:4a:bf:d9:90 Slot: 0 User Name:unknown IP Addr: unknown |
107 | Wed Oct 19 07:43:22 2011 | Client Deauthenticated: MACAddress:58:17:0c:4b:e3:80 Base Radio MAC:00:3a:98:4d:3e:d0 Slot: 0 User Name: unknown Ip Address: unknown Reason:Unspecified ReasonCode: 1 |
108 | Wed Oct 19 07:41:02 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:unknown IP Addr: unknown |
109 | Wed Oct 19 07:41:02 2011 | Client Deauthenticated: MACAddress:58:17:0c:4b:e3:80 Base Radio MAC:00:3a:98:66:4b:f0 Slot: 0 User Name: unknown Ip Address: 192.168.66.177 Reason:Unspecified ReasonCode: 1 |
110 | Wed Oct 19 07:38:29 2011 | Client Deauthenticated: MACAddress:00:22:5f:30:ed:28 Base Radio MAC:00:3a:98:5c:ea:40 Slot: 0 User Name: unknown Ip Address: 192.168.66.176 Reason:Unspecified ReasonCode: 1 |
111 | Wed Oct 19 07:35:36 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:3a:98:66:4b:f0 Slot: 0 User Name:unknown IP Addr: unknown |
112 | Wed Oct 19 07:35:25 2011 | Client Deauthenticated: MACAddress:58:17:0c:4b:e3:80 Base Radio MAC:00:3a:98:66:4b:f0 Slot: 0 User Name: unknown Ip Address: 192.168.66.177 Reason:Unspecified ReasonCode: 1 |
113 | Wed Oct 19 07:33:09 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:3a:98:5c:ea:40 Slot: 0 User Name:unknown IP Addr: 192.168.66.176 |
114 | Wed Oct 19 07:31:17 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
115 | Wed Oct 19 07:31:17 2011 | Client Deauthenticated: MACAddress:00:22:5f:30:ed:28 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.176 Reason:Unspecified ReasonCode: 1 |
116 | Wed Oct 19 07:31:16 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
117 | Wed Oct 19 07:30:00 2011 | Client Association: Client MAC:58:17:0c:4b:e3:80 Base Radio MAC :00:3a:98:66:4b:f0 Slot: 0 User Name:unknown IP Addr: unknown |
118 | Wed Oct 19 07:28:49 2011 | Coverage hole pre alarm for client[1] f8:1e:df:e7:ab:a5 on 802.11b/g interface of AP 00:3a:98:65:f0:b0 (Foaje). Hist: 0 0 0 0 1 7 22 54 99 155 126 51 19 4 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 |
119 | Wed Oct 19 07:26:45 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
120 | Wed Oct 19 07:25:53 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
121 | Wed Oct 19 07:25:52 2011 | Client Deauthenticated: MACAddress:00:22:5f:30:ed:28 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.176 Reason:Unspecified ReasonCode: 1 |
122 | Wed Oct 19 07:25:19 2011 | Client Association: Client MAC:f8:1e:df:e7:ab:a5 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.180 |
123 | Wed Oct 19 07:23:44 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
124 | Wed Oct 19 07:20:32 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
125 | Wed Oct 19 07:20:31 2011 | Client Deauthenticated: MACAddress:00:22:5f:30:ed:28 Base Radio MAC:00:3a:98:5c:ea:40 Slot: 0 User Name: unknown Ip Address: 192.168.66.176 Reason:Unspecified ReasonCode: 1 |
126 | Wed Oct 19 07:19:53 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
127 | Wed Oct 19 07:15:09 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:3a:98:5c:ea:40 Slot: 0 User Name:unknown IP Addr: unknown |
128 | Wed Oct 19 07:15:08 2011 | Client Deauthenticated: MACAddress:00:22:5f:30:ed:28 Base Radio MAC:00:1e:4a:c0:07:90 Slot: 0 User Name: unknown Ip Address: 192.168.66.176 Reason:Unspecified ReasonCode: 1 |
129 | Wed Oct 19 07:09:46 2011 | Client Association: Client MAC:00:22:5f:30:ed:28 Base Radio MAC :00:1e:4a:c0:07:90 Slot: 0 User Name:unknown IP Addr: unknown |
130 | Wed Oct 19 07:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
131 | Wed Oct 19 07:00:05 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:3a:98:65:f0:b0 |
132 | Wed Oct 19 06:36:38 2011 | Rogue AP : 00:22:07:0c:99:02 removed from Base Radio MAC : 00:3a:98:66:50:60 Interface no:0(802.11b/g) |
133 | Wed Oct 19 06:31:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
134 | Wed Oct 19 06:16:38 2011 | Rogue AP : 00:22:07:0c:99:02 detected on Base Radio MAC : 00:3a:98:66:50:60 Interface no:0(802.11b/g) with RSSI: -91 and SNR: 2 and Classification: unclassified |
135 | Wed Oct 19 06:10:06 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:3a:98:65:f0:b0 |
136 | Wed Oct 19 06:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
137 | Wed Oct 19 05:52:06 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
138 | Wed Oct 19 05:51:00 2011 | Client Association: Client MAC:58:1f:aa:21:5c:f7 Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:gjest IP Addr: 192.168.66.165 |
139 | Wed Oct 19 05:31:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
140 | Wed Oct 19 05:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
141 | Wed Oct 19 04:31:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
142 | Wed Oct 19 04:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
143 | Wed Oct 19 03:50:11 2011 | Client Deauthenticated: MACAddress:e0:f8:47:3f:8e:f4 Base Radio MAC:00:3a:98:4d:3e:d0 Slot: 1 User Name: unknown Ip Address: 192.168.66.169 Reason:Unspecified ReasonCode: 1 |
144 | Wed Oct 19 03:47:31 2011 | Client Association: Client MAC:e0:f8:47:3f:8e:f4 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 1 User Name:unknown IP Addr: unknown |
145 | Wed Oct 19 03:47:20 2011 | User gjest logged Out. Client MAC:e0:f8:47:3f:8e:f4, Client IP:192.168.66.169, AP MAC:00:3a:98:4d:3e:d0, AP Name:Forlegning_2.etg |
146 | Wed Oct 19 03:47:20 2011 | Client Deauthenticated: MACAddress:e0:f8:47:3f:8e:f4 Base Radio MAC:00:3a:98:4d:3e:d0 Slot: 0 User Name: gjest Ip Address: 192.168.66.169 Reason:Unspecified ReasonCode: 1 |
147 | Wed Oct 19 03:35:58 2011 | User gjest logged Out. Client MAC:00:21:6a:0e:05:2e, Client IP:192.168.66.166, AP MAC:00:3a:98:5c:ea:40, AP Name:Grupperom4 |
148 | Wed Oct 19 03:35:58 2011 | Client Deauthenticated: MACAddress:00:21:6a:0e:05:2e Base Radio MAC:00:3a:98:5c:ea:40 Slot: 1 User Name: gjest Ip Address: 192.168.66.166 Reason:Unspecified ReasonCode: 1 |
149 | Wed Oct 19 03:31:38 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
150 | Wed Oct 19 03:31:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
151 | Wed Oct 19 03:15:07 2011 | Client Deauthenticated: MACAddress:d8:2a:7e:65:e8:52 Base Radio MAC:00:3a:98:5c:ea:40 Slot: 0 User Name: gjest Ip Address: unknown Reason:Unspecified ReasonCode: 1 |
152 | Wed Oct 19 03:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
153 | Wed Oct 19 02:31:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
154 | Wed Oct 19 02:27:30 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
155 | Wed Oct 19 02:17:40 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
156 | Wed Oct 19 02:07:50 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
157 | Wed Oct 19 02:06:50 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
158 | Wed Oct 19 02:01:15 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
159 | Wed Oct 19 01:36:51 2011 | Client Association: Client MAC:64:b9:e8:2f:fd:a5 Base Radio MAC :00:3a:98:4d:3e:d0 Slot: 0 User Name:gjest IP Addr: 192.168.66.172 |
160 | Wed Oct 19 01:31:12 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
161 | Wed Oct 19 01:18:11 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:3a:98:65:f0:b0 |
162 | Wed Oct 19 01:02:11 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:3a:98:65:f0:b0 |
163 | Wed Oct 19 01:01:12 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
164 | Wed Oct 19 00:40:12 2011 | Decrypt errors occurred for client 00:24:d6:86:3c:4a using WPA key on 802.11b/g interface of AP 00:3a:98:65:f0:b0 |
165 | Wed Oct 19 00:31:12 2011 | Client Association: Client MAC:00:24:d6:86:3c:4a Base Radio MAC :00:3a:98:65:f0:b0 Slot: 0 User Name:host/NUSBLAP7.dsb.no IP Addr: 10.66.16.104 |
02-28-2012 10:25 AM
I am seeing similar issues on my controller as well. Was there ever any resolution to your issue bvj197222?
02-28-2012 10:12 PM
Kyle,
Do you see the decrypt errors along with your deauths?
Justin
03-01-2012 12:34 AM
Hello KyleHatfield,
Cisco did not have any good solutions to this. We also had a couple of consultants from our supplier here but they did not find out the reason to this. So we decided to swich to "WPA+WPA2". Now it works fine.
01-30-2013 08:42 AM
Hey Justin,
Wed Jan 30
18:11:28 2013
Wed Jan 30
18:10:21 2013
Wed Jan 30
18:08:27 2013
Wed Jan 30
18:05:14 2013
Wed Jan 30
18:01:04 2013
Wed Jan 30
17:55:07 2013
6
Wed Jan 30
17:53:27 2013
7
Wed Jan 30
17:44:13 2013
8
Wed Jan 30
17:39:11 2013
9
Wed Jan 30
17:23:19 2013
Wed Jan 30
17:21:21 2013
Wed Jan 30
17:11:59 2013
