You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Client reboots with Aironet
So far we have one Aironet 1100 setup with WPA security and SSID broadcast enabled. A Dell laptop with an internal wireless card is able to view the wireless network (SSID) but the laptop does not authenticate to the wireless network as this laptop uses the wired network. Since the Aironet has been turned on this laptop will occasionally reboot. When the wireless card in the laptop is disabled the laptop does not have the reboot issue. When the Aironet is powered off the same laptop does not have a reboot issue.
Below is the config and version info.
Thank you for any help.
version 12.3
no service pad
service password-encryption
hostname aironet2
no logging console
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
server 10.14.xxx.XXX auth-port 000 acct-port 000
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid wirelessnw
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 XXXXXXXXXXXBBBBBXXXX
username Admin privilege 15 password 7
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid mhqwn
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 80 in
interface BVI1
ip address 10.15.xxx.XXX 255.255.255.0
no ip route-cache
ip default-gateway 10.15.x.x
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.14.xxx.XXX auth-port 000 acct-port 000 key 7
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
line vty 0 4
Cisco IOS Software, C1100 Software (C1100-K9W7-M), Version 12.3(8)JEA, RELEASE )
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 23-Aug-06 16:30 by kellythw
ROM: Bootstrap program is C1100 boot loader
BOOTLDR: C1100 Boot Loader (C1100-BOOT-M) Version 12.3(2)JA4, RELEASE SOFTWARE )
System image file is "flash:/c1100-k9w7-mx.123-8.JEA/c1100-k9w7-mx.123-8.JEA"
cisco AIR-AP1121G-A-K9 (PowerPCElvis) processor (revision A0) with 15138K/1.
Processor board ID
PowerPCElvis CPU at 197Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address:
Part Number : 73-7886-10
PCA Assembly Number : 800-21481-10
PCA Revision Number : A0
PCB Serial Number :
Top Assembly Part Number : 800-28711-01
Top Assembly Serial Number :
Top Revision Number : A0
Product/Model Number : AIR-AP1121G-A-K9
Configuration register is 0xF
  • Other Wireless - Mobility Subjects
1 REPLY
Re: Client reboots with Aironet
What client adapter are you using on the Dell Laptop? Are you able to associate with the AP if you use a external wireless card. If that is the case then the problem could be with the internal client adapter. Could be that it is incompatible with the AP.
176
