Community Member
Clients disconnected from AP, Sending station has left the BSS
Issue Experienced
Clients randomly disconnects average time before disconnect is 15 minutes
Current AP running config
Current configuration : 2449 bytes
! Last configuration change at 16:49:26 UTC Mon Feb 24 2014
version 15.2
no service pad
service password-encryption
hostname BE-AP4
logging rate-limit console 9
enable secret 5 secret
no aaa new-model
no ip cef
dot11 syslog
dot11 vlan-name Manufacturing vlan 15
dot11 ssid BE-WAP1
   vlan 15
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 password
dot11 guest
power inline negotiation injector override
username admin privilege 15 password 7
bridge irb
interface Dot11Radio0
 no ip address
 no ip route-cache
 encryption mode ciphers tkip
 encryption vlan 15 mode ciphers tkip
 ssid BE-WAP1
 antenna gain 0
 antenna ab-antenna
 stbc
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15. m16. m17. m18. m19. m20. m21. m22. m23.
 channel 2442
 station-role root
interface Dot11Radio0.15
 encapsulation dot1Q 15 native
 no ip route-cache
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 no ip route-cache
 shutdown
 antenna gain 0
 peakdetect
 dfs band 3 block
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 no ip route-cache
 duplex auto
 speed auto
interface GigabitEthernet0.15
 no ip route-cache
 bridge-group 1
interface BVI1
 ip address 192.168.15.68 255.255.255.0
 no ip route-cache
ip default-gateway 192.168.15.254
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
Log Output
*Feb 24 15:39:30.226: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:39:44.446: %DOT11-6-ROAMED: Station 0017.23a9.b464 Roamed to 544a.00e1.e5c0
*Feb 24 15:39:44.446: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464 Reason: Sending station has left the BSS
*Feb 24 15:39:53.154: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:39:57.670: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:40:08.602: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230b.9bdf Associated KEY_MGMT[WPA PSK]
*Feb 24 15:40:49.662: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee2e Associated KEY_MGMT[WPA PSK]
*Feb 24 15:41:19.318: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee16 Associated KEY_MGMT[WPA PSK]
*Feb 24 15:43:31.622: %SYS-5-CONFIG_I: Configured from http by  on 192.168.1.97
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee16
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee2e
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230b.9bdf
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.1136
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b5e.cd44
*Feb 24 15:43:31.630: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.12ec
*Feb 24 15:43:31.642: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Feb 24 15:43:31.654: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 24 15:43:32.642: %DOT11-4-DIVER2_USED: Interface Dot11Radio0, Mcs rates 16-23 disabled due to only two transmit or receive antennas enabled
*Feb 24 15:43:32.654: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Feb 24 15:43:32.682: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 24 15:43:32.690: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Feb 24 15:43:32.698: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 24 15:43:33.726: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 24 15:43:33.746: %DOT11-4-MAXRETRIES: Packet to client 843a.4b5e.cd44 reached max retries, removing the client
*Feb 24 15:43:33.766: %DOT11-4-MAXRETRIES: Packet to client 843a.4b55.12ec reached max retries, removing the client
*Feb 24 15:43:34.726: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Feb 24 15:43:36.210: %SYS-5-CONFIG_I: Configured from http by  on 192.168.1.97
*Feb 24 15:44:09.450: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 15:45:27.522: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 843a.4b5e.cd44 Associated KEY_MGMT[WPA PSK]
*Feb 24 15:45:27.526: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 843a.4b55.12ec Associated KEY_MGMT[WPA PSK]
*Feb 24 15:45:27.890: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230b.9bdf Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:28.614: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee16 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:28.842: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee6b Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:28.850: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.c1e8 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:28.862: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:28.866: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b461 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:29.102: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:29.110: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:45:29.350: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee2e Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:47:17.174: %DOT11-7-AUTH_FAILED: Station cc3a.6194.ec3c Authentication failed
*Feb 24 15:48:32.938: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:48:38.150: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:49:11.446: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:49:23.094: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:49:56.018: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 843a.4b55.1136 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 15:50:44.850: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:50:52.198: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:50:58.106: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:51:44.738: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:51:50.150: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:51:58.738: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 15:55:27.622: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.12ec Reason: Sending station has left the BSS
*Feb 24 15:55:27.650: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 843a.4b55.12ec Associated KEY_MGMT[WPA PSK]
*Feb 24 16:01:57.442: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 16:05:48.854: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461 Reason: Sending station has left the BSS
*Feb 24 16:06:28.310: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 16:06:50.414: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464 Reason: Sending station has left the BSS
*Feb 24 16:06:56.102: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474 Reason: Sending station has left the BSS
*Feb 24 16:08:13.282: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b461 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:08:13.914: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:08:15.870: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:08:28.066: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8 Reason: Sending station has left the BSS
*Feb 24 16:08:34.610: %DOT11-6-ROAMED: Station 0017.230b.9bdf Roamed to 544a.00e1.ef70
*Feb 24 16:08:34.610: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230b.9bdf Reason: Sending station has left the BSS
*Feb 24 16:08:34.622: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461 Reason: Sending station has left the BSS
*Feb 24 16:08:34.934: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474 Reason: Sending station has left the BSS
*Feb 24 16:08:35.846: %DOT11-6-ROAMED: Station 0017.230a.ee6b Roamed to 00e1.6d4f.6090
*Feb 24 16:08:35.846: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee6b Reason: Sending station has left the BSS
*Feb 24 16:08:36.394: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464 Reason: Sending station has left the BSS
*Feb 24 16:08:36.398: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b464 reached max retries, removing the client
*Feb 24 16:08:37.426: %DOT11-6-ROAMED: Station 0017.230a.ee2e Roamed to 00e1.6d4f.6090
*Feb 24 16:08:37.426: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee2e Reason: Sending station has left the BSS
*Feb 24 16:08:57.994: %DOT11-6-ROAMED: Station 0017.230a.ee16 Roamed to 544a.00e1.e5c0
*Feb 24 16:08:57.994: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee16 Reason: Sending station has left the BSS
*Feb 24 16:10:00.562: %DOT11-7-AUTH_FAILED: Station cc3a.6194.ec3c Authentication failed
*Feb 24 16:10:00.562: %DOT11-4-MAXRETRIES: Packet to client cc3a.6194.ec3c reached max retries, removing the client
*Feb 24 16:12:41.694: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Sending station has left the BSS
*Feb 24 16:13:06.994: %DOT11-7-AUTH_FAILED: Station cc3a.6194.ec3c Authentication failed
*Feb 24 16:13:47.870: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 16:16:24.822: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 16:16:32.262: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 16:16:46.838: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 16:16:56.050: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 16:17:16.262: %DOT11-7-AUTH_FAILED: Station 0017.2313.c7bc Authentication failed
*Feb 24 16:20:37.806: %DOT11-4-MAXRETRIES: Packet to client f409.d8b0.313d reached max retries, removing the client
*Feb 24 16:20:37.806: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Previous authentication no longer valid
*Feb 24 16:20:37.810: %DOT11-4-MAXRETRIES: Packet to client f409.d8b0.313d reached max retries, removing the client
*Feb 24 16:20:39.142: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 16:21:40.406: %DOT11-6-ROAMED: Station f409.d8b0.313d Roamed to 544a.00e1.ef70
*Feb 24 16:21:40.406: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Sending station has left the BSS
*Feb 24 16:25:45.006: %DOT11-7-AUTH_FAILED: Station f409.d8b0.313d Authentication failed
*Feb 24 16:25:45.010: %DOT11-4-MAXRETRIES: Packet to client f409.d8b0.313d reached max retries, removing the client
*Feb 24 16:31:32.954: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:33.654: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.c1e8 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:36.866: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee6b Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:38.538: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee2e Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:38.666: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:40.526: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee16 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:42.414: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230b.9bdf Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:51.362: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b461 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:31:53.554: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:44:45.258: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 16:47:39.350: %DOT11-6-ROAMED: Station 6c88.145d.0db8 Roamed to 544a.00e1.ef70
*Feb 24 16:47:39.350: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Sending station has left the BSS
*Feb 24 16:49:26.394: %SYS-5-CONFIG_I: Configured from http by  on 192.168.1.97
*Feb 24 16:49:26.398: %SYS-5-CONFIG_I: Configured from http by  on 192.168.1.97
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230b.9bdf
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee16
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee2e
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee6b
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.12ec
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.1136
*Feb 24 16:49:26.398: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b5e.cd44
*Feb 24 16:49:26.410: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Feb 24 16:49:26.422: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Feb 24 16:49:27.414: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Feb 24 16:49:27.442: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Feb 24 16:49:27.450: %DOT11-4-MAXRETRIES: Packet to client 843a.4b55.12ec reached max retries, removing the client
*Feb 24 16:49:27.502: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b464 reached max retries, removing the client
*Feb 24 16:49:27.510: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b470 reached max retries, removing the client
*Feb 24 16:49:27.522: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.c1e8 reached max retries, removing the client
*Feb 24 16:49:27.530: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b461 reached max retries, removing the client
*Feb 24 16:49:27.530: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b474 reached max retries, removing the client
*Feb 24 16:49:27.594: %DOT11-4-MAXRETRIES: Packet to client 0017.230a.ee2e reached max retries, removing the client
*Feb 24 16:49:28.134: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230b.9bdf Associated KEY_MGMT[WPA PSK]
*Feb 24 16:49:28.442: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Feb 24 16:49:29.806: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee2e Associated KEY_MGMT[WPA PSK]
*Feb 24 16:49:35.038: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:37.294: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee16 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:37.418: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.230a.ee6b Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:41.622: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.c1e8 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:41.642: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:41.726: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b461 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:42.522: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:42.886: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b464 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 16:49:57.310: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 16:50:02.818: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Sending station has left the BSS
*Feb 24 16:50:06.014: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 16:52:37.670: %DOT11-7-AUTH_FAILED: Station 9018.7cb5.01f5 Authentication failed
*Feb 24 16:57:13.026: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474 Reason: Sending station has left the BSS
*Feb 24 16:57:13.034: %DOT11-4-MAXRETRIES: Packet to client 0017.23a9.b474 reached max retries, removing the client
*Feb 24 16:58:37.262: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b464 Reason: Sending station has left the BSS
*Feb 24 16:58:43.302: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461 Reason: Sending station has left the BSS
*Feb 24 16:58:46.710: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8 Reason: Sending station has left the BSS
*Feb 24 16:58:48.338: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 17:02:27.078: %DOT11-7-AUTH_FAILED: Station 9018.7cb5.01f5 Authentication failed
*Feb 24 17:04:45.486: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 843a.4b55.12ec Reassociated KEY_MGMT[WPA PSK]
*Feb 24 17:04:46.514: %DOT11-7-AUTH_FAILED: Station 9018.7cb5.01f5 Authentication failed
*Feb 24 17:19:47.858: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Sending station has left the BSS
*Feb 24 17:19:59.694: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.c1e8 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 17:25:36.682: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 17:26:40.910: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 17:27:01.002: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 17:27:27.390: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 17:27:47.626: %DOT11-4-MAXRETRIES: Packet to client f409.d8b0.313d reached max retries, removing the client
*Feb 24 17:27:47.626: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Previous authentication no longer valid
*Feb 24 17:27:47.630: %DOT11-4-MAXRETRIES: Packet to client f409.d8b0.313d reached max retries, removing the client
*Feb 24 17:31:49.458: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8 Reason: Sending station has left the BSS
*Feb 24 17:32:53.530: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 843a.4b55.12ec Reason: Sending station has left the BSS
*Feb 24 17:40:59.858: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.c1e8 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 18:08:22.578: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.c1e8 Reason: Sending station has left the BSS
*Feb 24 18:36:31.482: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230b.9bdf Reason: Previous authentication no longer valid
*Feb 24 18:57:16.774: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 18:57:25.642: %DOT11-7-AUTH_FAILED: Station f409.d8b0.313d Authentication failed
*Feb 24 18:57:38.958: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  f409.d8b0.313d Associated KEY_MGMT[WPA PSK]
*Feb 24 18:59:28.442: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 19:23:40.450: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 19:40:30.433: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Sending station has left the BSS
*Feb 24 19:40:30.449: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 19:45:30.009: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Sending station has left the BSS
*Feb 24 19:45:38.109: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 19:48:41.953: %DOT11-4-MAXRETRIES: Packet to client 6c88.145d.0db8 reached max retries, removing the client
*Feb 24 19:48:41.953: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Previous authentication no longer valid
*Feb 24 19:48:42.029: %DOT11-4-MAXRETRIES: Packet to client 6c88.145d.0db8 reached max retries, removing the client
*Feb 24 19:48:45.305: %DOT11-6-ASSOC: Interface Dot11Radio0, Station BE-AP4 6c88.145d.0db8 Associated KEY_MGMT[WPA PSK]
*Feb 24 19:52:20.877: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb 24 19:52:21.877: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb 24 19:52:30.957: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb 24 19:52:31.957: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Feb 24 19:57:43.173: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6c88.145d.0db8 Reason: Sending station has left the BSS
*Feb 24 20:00:09.885: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b433 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:01:08.445: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b465 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:01:25.453: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b453 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:01:47.549: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b449 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:02:07.469: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b456 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:02:23.713: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b5da Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:02:45.761: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b466 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:02:53.133: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b449 Reason: Sending station has left the BSS
*Feb 24 20:02:57.913: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b456 Reason: Sending station has left the BSS
*Feb 24 20:03:14.521: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b5db Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:03:24.673: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b466 Reason: Sending station has left the BSS
*Feb 24 20:03:29.653: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b453 Reason: Sending station has left the BSS
*Feb 24 20:03:39.125: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b458 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:03:49.093: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b5da Reason: Sending station has left the BSS
*Feb 24 20:03:51.113: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b5d7 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:03:52.549: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b5da Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:03:54.905: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b433 Reason: Sending station has left the BSS
*Feb 24 20:04:12.565: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b458 Reason: Sending station has left the BSS
*Feb 24 20:04:19.213: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b5db Reason: Sending station has left the BSS
*Feb 24 20:04:22.865: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b465 Reason: Sending station has left the BSS
*Feb 24 20:04:24.965: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b465 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:04:26.341: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b433 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:04:27.089: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b5d7 Reason: Sending station has left the BSS
*Feb 24 20:05:29.437: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b5d7 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:06:46.761: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b470 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:06:50.233: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b474 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:07:03.725: %DOT11-6-ASSOC: Interface Dot11Radio0, Station CBP BE 0017.23a9.b461 Reassociated KEY_MGMT[WPA PSK]
*Feb 24 20:07:52.513: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee16 Reason: Previous authentication no longer valid
*Feb 24 20:08:09.513: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.230a.ee6b Reason: Previous authentication no longer valid
*Feb 24 20:08:40.685: %DOT11-6-ROAMED: Station f409.d8b0.313d Roamed to 2c3e.cf54.f590
*Feb 24 20:08:40.685: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f409.d8b0.313d Reason: Sending station has left the BSS
*Feb 24 20:09:40.053: %DOT11-7-AUTH_FAILED: Station f409.d8b0.313d Authentication failed
*Feb 24 20:31:25.833: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b433 Reason: Sending station has left the BSS
*Feb 24 20:31:29.373: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b5d7 Reason: Sending station has left the BSS
*Feb 24 20:31:52.053: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b5da Reason: Sending station has left the BSS
*Feb 24 20:32:29.245: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b465 Reason: Sending station has left the BSS
*Feb 24 20:33:46.221: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b470 Reason: Sending station has left the BSS
*Feb 24 20:33:49.717: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b474 Reason: Sending station has left the BSS
*Feb 24 20:34:03.213: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0017.23a9.b461 Reason: Sending station has left the BSS
Everyone's tags (1)
VIP Purple
Hiif you want to get any
if you want to get any higher data rates (802.11n) you have to configure WPA2/AES & not TKIP
dot11 ssid BE-WAP1
   vlan 15
   authentication open
   authentication key-management wpa version 2
   guest-mode
 encryption vlan 15 mode ciphers aes-ccm
 no encryption vlan 15 mode ciphers tkip
 ssid BE-WAP1
Also enable 5GHz band as well. Then see if the problem occurs for both bands
 ssid BE-WAP1
 channel width 40-above
 no shut
 bridge-group 1
Rasika
**** Pls rate all useful responses ****
Community Member
Thank you for the advise on
Thank you for the advise on increasing performance
Since there were multiple installs of the same access points, I copied and paste the config including the key. I think this may have been the issue, once I've gone in and manually configured the SSID key on each, I have not received any complaints on the issue.
Will keep everyone updated on this thread in case someone else runs into this issue in the future.
VIP Purple
Thanks for the update & seems
Thanks for the update & seems promising.
Keep us posting if any issues
**** Pls do not forget to rate our responses if that useful to you ****
Rasika
Community Member
Issue still exists, I will
Issue still exists, I will try changing the encryption. Not sure what else to try.
Community Member
Thanks for your posts Mark.
Thanks for your posts Mark. Did you ever resolve this problem?
 I have a very similar issue. Clients are disconnected from AP after 15-20min. The problem just suddenly cropped up the past few months. 8 AP's spread accross 4 floors, 80k sq ft building. Config was copied and pasted to numerous AP's over time. We tried everything you mentioned above. Please lmk if you have a fix.
logging and config below.
Thank you,
Jim
#show logging | i 3059.b714.a224
Oct 12 11:04:34.189: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:06:17.062: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:06:19.582: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:06:26.039: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:06:28.504: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:07:41.741: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:07:44.159: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:07:49.412: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:07:49.412: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Previous authentication no longer valid
Oct 12 11:07:49.419: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:07:49.845: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:07:50.166: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:07:53.277: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:07:57.761: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:08:00.285: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:08:36.886: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:08:36.886: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Previous authentication no longer valid
Oct 12 11:08:36.922: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:08:52.688: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:08:55.208: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:09:27.875: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:09:30.261: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:09:30.914: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:09:34.175: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:09:41.365: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:09:43.842: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:11:35.028: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:11:37.538: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:11:44.496: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:11:46.876: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:12:23.345: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:12:23.363: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:13:56.438: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:13:58.916: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:14:32.652: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:14:39.408: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:16:42.984: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:16:43.003: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:17:22.414: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:17:24.927: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:17:30.243: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:17:30.243: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Previous authentication no longer valid
Oct 12 11:17:30.249: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:17:30.404: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:17:59.088: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:17:59.112: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:18:00.224: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:18:03.525: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:24:31.156: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:24:33.589: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:24:40.539: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:24:40.595: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:24:45.565: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:24:48.543: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2]
Oct 12 11:24:53.871: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:24:53.872: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3059.b714.a224 Reason: Previous authentication no longer valid
Oct 12 11:24:53.873: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:24:56.676: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   3059.b714.a224 Associated KEY_MGMT[WPAv2-CP]
Oct 12 11:24:56.688: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 3059.b714.a224 Reason: Sending station has left the BSS
Oct 12 11:25:05.301: %DOT11-4-MAXRETRIES: Packet to client 3059.b714.a224 reached max retries, removing the client
Oct 12 11:25:05.301: Client 3059.b714.a224 failed: reached maximum retries
#show running-config
Building configuration...
Current configuration : 4494 bytes
version 12.4
no service pad
hostname SP_AP4thFL
enable secret 5 $1$xEZz$CcCVHXEBj4VNt8861QuvB1
aaa new-model
aaa group server radius rad_eap
 server [ip] auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
aaa group server radius rad_admin
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
ip domain name kci.local
dot11 syslog
dot11 vlan-name GuestWireless vlan 4
dot11 vlan-name LAN vlan 1
dot11 ssid SSID1
   vlan 1
   authentication open eap eap_methods1
   authentication network-eap eap_methods1
dot11 ssid SSID2
   vlan 4
   authentication open
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 999999999999999
power inline negotiation prestandard source
username adminusername privilege 15 password 7 999999999999999
username otheradmin privilege 15 password 7 9999999999999999
bridge irb
 no ip address
 no ip route-cache
 encryption vlan 1 mode ciphers aes-ccm
 encryption vlan 4 mode ciphers aes-ccm
 encryption mode ciphers aes-ccm
 ssid SSID1
 ssid SSID2
 antenna gain 0
 speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 basic-m0. basic-m1. basic-m2. basic-m3. basic-m4. basic-m5. basic-m6. basic-m7. basic-m8. basic-m9. basic-m10. basic-m11. basic-m12. basic-m13. basic-m14. basic-m15.
 channel 2417
 station-role root
 encapsulation dot1Q 1 native
 no ip route-cache
 bridge-group 1
interface Dot11Radio0.4
 encapsulation dot1Q 4
 no ip route-cache
 bridge-group 4
 bridge-group 4 subscriber-loop-control
 bridge-group 4 block-unknown-source
 no bridge-group 4 source-learning
 no bridge-group 4 unicast-flooding
 bridge-group 4 spanning-disabled
 no ip address
 no ip route-cache
 ssid SID1
 ssid SID2
 antenna gain 0
 dfs band 3 block
 channel dfs
 station-role root
interface Dot11Radio1.1
 no ip route-cache
 bridge-group 1
interface Dot11Radio1.4
 no ip route-cache
 bridge-group 4
 no ip address
 no ip route-cache
 duplex auto
 speed auto
 no keepalive
 no ip route-cache
 bridge-group 1
interface GigabitEthernet0.4
 no ip route-cache
 bridge-group 4
interface BVI1
 ip address [ip] 255.255.252.0
 no ip route-cache
ip default-gateway [ip]
ip http server
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host [ip] auth-port 1645 acct-port 1646 key 7 06050A2F585C291508371C0C5F45
radius-server vsa send accounting
bridge 1 route ip
line con 0
 transport output none
line vty 0 4
 transport input telnet ssh
end
Community Member
Re entering the key seems to
Re entering the key seems to have resolved the issue. Config was copied and paste across multiple APs during implementation. Also applied updated IOS
Never had this issue in the past
Rasika,
Rasika,
Just used this tip to fix an issue with my wife laptop dropping off and not performing that well, kill TKIP.
Thanks, just realised who it was from! :-)
Rod.
VIP Purple
Hi Rodney,
Hi Rodney,
Nice to hear from you and specially in this way.
Glad to see this thread helps you to improve your WiFi experience.
KIT
Rasika
3805
