Community Member
CNFGR-5-LIC_REQUEST_FAILURE on WLC 2504
Hello everybody.
Today I found some messages on my wlc 2504 controller in message log:
*spamApTask5: Feb 04 16:27:27.854: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
[...It occurred 2 times/sec!.]
*spamApTask6: Feb 04 16:26:00.859: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask1: Feb 04 16:25:56.590: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask5: Feb 04 16:25:27.866: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask6: Feb 04 16:24:00.870: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask1: Feb 04 16:23:56.602: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask5: Feb 04 16:23:27.877: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask6: Feb 04 16:22:00.881: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask1: Feb 04 16:21:56.614: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask5: Feb 04 16:21:27.889: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask6: Feb 04 16:20:00.891: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
*spamApTask1: Feb 04 16:19:56.627: #CNFGR-5-LIC_REQUEST_FAILURE: cnfgr.c:1442 License request for feature data_encryption failed, return code is 18
The wireless network is working well, but the massage errors always occurs.
Please help me solve this problem and understand what's going.
Thank you very much in advance.
Kind regards,
Dwi
VIP Purple
Hi Dwi,
Can you paste the output of this command from WLC: sh syinfo
Normally DTLS license will be installed later then 7.0 code on WLC. In sh sysinfo you will  see this , DTLS license needs to enable data encryption.
Check this :
Build Type....................................... DATA + WPS + LDPE
If its there then there is no worry.
Reagrds
Community Member
Dear sandeepchoudhary21,
thank you for you explanation, but this is the output
so do i have to enable data encrytion on dtls license ?
http://www.cisco.com/en/US/docs/wireless/controller/5700/software/release/3se/lwap/configuration_guide/b_ap-config_32se_5700_cg_chapter_011.html
thank you very much
VIP Purple
HI,
The main question here is : Your WLAN is working perfectly and still you are getting logs. If you are running 7.0.220.0 or higher, you have the license installed because it is inbuilt image.
But you can follow this thread :  https://supportforums.cisco.com/thread/2132281
If you want to know more detail about this then you can raise a TAC case or you can send a mail to licensing@cisco.com
Dont forget to arte helpful posts
367
