Compare Config
j.williams
We have a Cisco AIR-AP1852E-E-K9 which is running Cisco Aironet 1850 Series Mobility Express version 8.3.130.0, We also have a Cisco C891FW which is running CAPWAP, I need to configure the C891FW to match the Air-AP, Is there a way I can compare the config between both devices? So when the C891 is installed a user can auto connect to the Wireless without any issues
Hi @j.williams
 Compare the config is easy task. You need to connect to the AP and copy/paste the output to a txt file, them, you can use Compareit program.
-If I helped you somehow, please, rate it as useful.-
What command would I use? Sh running-config?
Yeah, show running-config.
