06-10-2012 11:12 AM - edited 07-03-2021 10:16 PM
Can we configure the wireless controller 5508 to authenticate the clients using both of MAC address Filtering (layer 2 security) and Web authentication (layer 3 security). and what is the difference between (Web policy --> authentication) and (Web policy --> on MAC filter failure)
Has anyone configured this security feature before ?
Plz advice
06-10-2012 02:02 PM
Here is the link where you can check on the layer 2 and layer 3 compatibility Matrix.
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080987b7c.shtml
06-11-2012 01:40 AM
thanks Fbarboza for reply
actually the link you mentioned above did not open ,, could you plz send another link.
06-10-2012 03:55 PM
Yes, If a WLAN has both a Layer 2 (mac-filter) and Layer 3 security (webauth-on-macfilter-failure) configured, the client moves to RUN state if either one is passed. And if it fails Layer 2 security (mac-filter), the client is moved to Layer 3 security (webauth-on-macfilter-failure) i.e, when clients fail on MAC filter, they get automatically switched to webAuth.
Web policy --> authentication, it can or can't be used with mac filter, if mac filter enabled then it will be mandatory & can't fail to webauth like above.
06-11-2012 01:45 AM
thanks Saravanan for ur reply.
in our organization we need to perform double layer of security
firstly a MAC Filter for specific clients and after successfully passed the local filter in Wireless controller, the clients need to perform a web policy authentication by writing the username and password which are configured locally in the wireless controller database too.
is it possible ??
06-11-2012 03:33 AM
Salam Hussein,
Yes it is possible.
You can enable mac-filtering on L2 security on the WLAN and webauth (on L3 security) at the same time.
Amjad
06-11-2012 10:09 PM
thanks alot Amjad..
