Configuring Aironet 1040 with WPA2-PSK
I am attempting to configure two Aironet 1040 series wireless access points for the first time and am having some difficulty. This office does not have a RADIUS server so I would like to set them up to use WPA2 with a pre-shared key. However just how this is accomplished is not immediately apparent. I have attempted using both the command line interface and the web interface, but I get errors in both places. It doesn't seem like it is all that difficult, we're just talking about a few lines in the configuration file.
This is what I have so far:
Current configuration : 1684 bytes
version 12.4
no service pad
service password-encryption
hostname ap1
logging rate-limit console 9
enable secret 5 $1$q9i9$V8Z042Zif0H7t4qN5awMM.
no aaa new-model
ip domain name Office
dot11 syslog
dot11 ssid WLAN
   vlan 30
   authentication open
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid WLAN
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid WLAN
antenna gain 0
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface BVI1
ip address 192.168.2.2 255.255.255.0
no ip route-cache
ip default-gateway 192.168.2.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
access-list 111 permit tcp any any neq telnet
bridge 1 route ip
line con 0
access-class 111 in
line vty 0 4
access-class 111 in
login local
end
  • Other Wireless - Mobility Subjects
Everyone's tags (4)
1 REPLY
OK, I figured out some of what was going on. The admin account was set to read only instead of read/write, and both radios had not been added to my VLAN. Now I have successfully (?) configured WPA2-PSK on both wireless access points, and they are broadcasting their SSIDs, but I am unable to connect to them for an unknown reason. I am prompted for the pre shared key and then the connection fails. Hmm...
1876
