Community Member
Configuring DHCP Server on a 1130AG?
Can it be done? I found the article, i followed it but still cant get it to work. I did some other research on the web, some people say it cant be done, where as the cisco documentation says it can be.
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38adm.html#wpmkr1090318
I can see the AP, but the client will not get a IP from the AP. here is my config.
version 12.4
no service pad
service password-encryption
hostname xxx
enable secret xxx
no aaa new-model
clock timezone -0500 -5
clock summer-time -0400 recurring
ip domain name xxx
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.201.1 192.168.201.20
ip dhcp pool Home
network 192.168.201.0 255.255.255.0
default-router 192.168.201.1
lease 10
ip dhcp-server 192.168.201.1
dot11 ssid hidden
authentication open
authentication key-management wpa
wpa-psk ascii xxx
dot11 ssid hiddena
authentication open
wpa-psk ascii xxx
power inline negotiation prestandard source
username Cisco password xxx
username spmadmin privilege 15 password xxx
bridge irb
interface Dot11Radio0
ip address 192.168.201.1 255.255.255.0
no ip route-cache
encryption mode ciphers tkip
ssid hidden
speed basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid hiddena
dfs band 3 block
speed basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
ip address x.x.x.x 255.255.255.248
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip default-gateway x.x.x.x
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community xxxx RO
bridge 1 route ip
banner motd
Unauthorized access is prohibited. If this was accidental, please disconnect immediately.
line con 0
line vty 0 4
login local
sntp broadcast client
end
Any help would be greatly appreciated.
Thanks in advance.
Ed
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Configuring DHCP Server on a 1130AG?
No problem. There are some Cisco products like the 871W that is router and wireless access point, but it also comes with a price more than what you can get for a Linksys or other SOHO vendors.
-Scott
Your subnet mask doesn't match.. the clients will be put on the same subnet as the ap is on. Change it to 255.255.255.0 on the BVI interface.
Here is an example:
ip dhcp excluded-address 192.168.201.200 192.168.201.254
ip dhcp pool DHCP
lease 0 0 10
dot11 ssid surveya
authentication open
dot11 ssid surveyg
authentication open
guest-mode
no ip address
no ip route-cache
ssid surveyg
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
no ip address
no ip route-cache
ssid surveya
station-role root
bridge-group 1
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.201.254 255.255.255.0
no ip route-cache
-Scott
Community Member
what if my bv1 interface has a public IP?
basically I am setting up a public AP, with just basic WPA and WPA2 passkeys. I have this connected to business cable line, but the business cable only has 5 usable IPs.
I set the bv1 to a private ip with the subnet, but i can no longer access it remotely or connect to the internet from within the AP.
You need a router to be able to NAT users. What is your setup anyways... You might need to get a router with wireless or maybe just a Linksys router or something like that.
-Scott
Community Member
Thanks. You just confirmed what i thought, I will probably just get a linksys router and let that handle the DHCP and NAT, it would make the config much more simpler.
in my crazy mind, i thought the wireless could do NAT and DHCP, it would have been nice, but maybe i should have done more research.
-Scott
2290
