COnfiguring NAT on Cisco 1800ISR
I have been evaluting a Cisco 1800ISR but I am not able to configure the NAT to work with a host from inside our network to an outside IP address. I have setup a test network in 192.168.x.x network and I am trying to NAT an unusde IP address from our internal network to the test network.
1 REPLY
Re: COnfiguring NAT on Cisco 1800ISR
Here is a link to configure NAT:
http://www.cisco.com/warp/public/556/12.html
NAT ( Remember that you need to use a public ip address to enable the internal LAN to reach the Internet )
router>enable
router#config t
router(config)#ip nat inside source list 120 interface [name of the outisde
interface] overload
router(config)#access-list 120 permit ip [address of the LAN] [inverse mask
of the LAN ] any
router(config)#int [name of the interface ] <---LAN interface
router(config-if)#ip nat inside
router(config-if)#exit
router(config)#int [name of the interface ] <---INTERNET interface
router(config-if)#ip nat outside
If you have a internal server ( web, exchange for example ) that the
Internet will access you need to use static nat .
router>enable
router#config t
router(config)#ip nat inside source static x.x.x.x y.y.y.y <----where
x.x.x.x is the internal ip and y.y.y.y is the public ip
router(config)#exit
Here are some more useful links related to NAT:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/113ed_cr/d
ial_c/dcprt11/dcnat.htm#xtocid1349912
http://www.cisco.com/en/US/partner/tech/tk648/tk361/tk438/tech_protocol_home
.html
259
