Configuring Universal Client Mode on 877W
I have a 877W with a c870-advsecurityk9-mz.124-4.T6 IOS.
And Id like to configure it in Universal Client Mode, I've seen in the doc that it's possible , but can't find any doc on how to do it.
When I go in "station-role" in the dot11 interface, I have only "root". If I have understood whet I've read, I need to put non-root here...
Do I need a other IOS for that ?
My goal is to connect a netgear WG302 to the cisco by wifi.
I need an ethernet and a wifi lan accessing internet but without contact between them.
And I want the WG302 to extend the wifi range...
I know it would be easily with a cisco AP, but my customer already has the WG302.
Thanks for your help.
1 REPLY
Re: Configuring Universal Client Mode on 877W
I have exactly the same problem.
I used "Software Advisor" to find an IOS which support "Universal Client Mode" feature.
As you can see the result of my research:
http://www.imagehosting.com/show.php/1500843_851UCM.JPG.html
IOS c850-advsecurityk9-mz.12.4-15.T1 should be a compatible release with my Cisco 851 and should support this functionality.
But, I can't configure “Universal Client Mode”, “station-role non-root” doesn't exist.
Is it normal?
Should I open a case?
407
