Configuring WDS with cisco 1242 APs
Hi Guys,
I'm using two cisco 1242 AG access points to configure WDS feature. I've named the accesspoints as AP1(acts as WDS) and AP2. Since I've only two accesspoints, I've configured the AP1 to act both as a WDS and as a regular accesspoints.
Further I'm using the local radius server within the AP1 to authenticate both clients and infrastructure accesspoints. And both APs are connected to a router (which act as a dhcp server) via a unmanageble switch and both accesspoints are getting registered with WDS.
But the issue is when I tried to connect to the configured SSID, it promts me a "authendication window" but after entering the configured username and password, i'm not getting authenticated by the AP.
I've attached the configurations of both APs to for your reference and I've used the following cisco document as a guideline to crate the WDS.
http://www.cisco.com/en/US/products/hw/wireless/ps458/products_configuration_example09186a008059a559.shtml
Can someone assist me with this regard.
Suthakar
////////////// AP1 ///////////
ap1#sh run
Building configuration...
Current configuration : 3403 bytes
version 12.4
no service pad
service password-encryption
hostname ap1
enable secret 5 $1$AuxA$wvJa8q/5LgU9Var9/FqGz1
aaa new-model
aaa group server radius rad_eap
server 196.175.100.204 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius clients
server 196.175.100.204 auth-port 1645 acct-port 1646
aaa authentication login wds-server group rad_eap
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login method_clients group clients
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid cisco123
authentication open eap method_clients
authentication network-eap method_clients
authentication key-management wpa
guest-mode
power inline negotiation prestandard source
username Cisco password 7 05280F1C2243
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid cisco123
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid cisco123
no dfs band block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 196.175.100.204 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com...config/help/eag
ip radius source-interface BVI1
radius-server local
no authentication eapfast
no authentication mac
nas 196.175.100.204 key 7 01100F175804
user AP1242 nthash 7 025327035B5629701F6F5A3A204F442E28567F7F740C1761074454455 2240F780A
user user1 nthash 7 075D796D6B5C4C5D444A5F2F20087373716B13764325355424770B0975 702B224D
user ap1 nthash 7 14454A2A29517F737770671606315F415A59700D08717759263944087E73 767300
radius-server attribute 32 include-in-access-req format %h
radius-server host 196.175.100.204 auth-port 1812 acct-port 1813 key 7 070C285F4 D06
radius-server host 196.175.100.204 auth-port 1645 acct-port 1646 key 7 00071A150 754
radius-server vsa send accounting
bridge 1 route ip
wlccp ap username ap1 password 7 105A01180E0513075D
wlccp authentication-server infrastructure wds-server
wlccp authentication-server client mac method_clients
wlccp authentication-server client eap method_clients
wlccp authentication-server client leap method_clients
wlccp authentication-server client any method_clients
wlccp wds priority 254 interface BVI1
line con 0
line vty 0 4
end
ap1#
//////////////// AP2 ////////////////
ap2#sh run
Current configuration : 2558 bytes
version 12.4
no service pad
hostname ap2
enable secret 5 $1$UuwI$Do4iUfHGJDBHSDl9pjAGu/
aaa new-model
aaa group server radius rad_eap1
aaa authentication login eap_methods1 group rad_eap1
dot11 ssid cisco123
authentication open eap eap_methods1
authentication network-eap eap_methods1
bridge irb
no ip address
no ip route-cache
ssid cisco123
station-role root
bridge-group 1
no ip address
no ip route-cache
ssid cisco123
no dfs band block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 196.175.100.205 255.255.255.0
no ip route-cache
ip http server
ip http help-path
radius-server host 196.175.100.204 auth-port 1645 acct-port 1646 key 7 030752180 500
bridge 1 route ip
wlccp ap username AP1242 password 7 045802150C2E
line con 0
line vty 0 4
end
ap2#
Step 1 is verifying that WDS infrastructure is correct. From there we can worry about the clients.
Can you type "show wlccp ap" and "show wlccp wds ap" ?
It should show if the 2nd AP is registered to the 1st one.
If that is all fine, we'd go with radius and aaa debugs on the WDS AP.
Dear Nicolas,
I've issued the both "show wlccp wds ap" and "show wlccp ap" commands and it simply shows
that the 2nd ap is getting resigstered with the 1st one. Further since i'm using the 1st ap
as to serve as both client and wds, under the 1st ap's wds configuration tab/page i can see
that both aps are getting regsitered as clients.
Anyhow let me run the "radius and aaa" debug commands and see........
suthakar
Bronze
Re: Configuring WDS with cisco 1242 APs
When you perform the "#show wlccp wds ap" command you should see both the WDS master (ap1) and AP2 registered.
In AP1's radius-server local confiig, I show the shared key for AP2 and applicable username
You should also add the radius server to this list
# radius-server local
# nas 196.175.100.205 key 0
It looks like you already have the username created and set under your wlccp config
and
Once you see AP1 and AP2 registered with show wlccp wds ap see what you get.
Also, on AP2, you will call the same key-management, auth, etc "eap" methods group under your SSID as used on AP1.  All of this information will hit the AP1 WDS master and use AP1s designated groups and host lists.  This is the reason you have the following commands on your master. Requests from received at the WDS slave will be forwarded to the master and handled accordingly.
wlccp authentication-server infrastructure ...
wlccp authentication-server client ...
You should not even need to declare your radius server groups, or define hosts on AP2, only the master.  Just using your wlccp command that is in place will work.
1893
